Carbon footprint Turn your lights off - Does it really make a difference?
The discussion revolves around the impact of individual actions, such as turning off lights and appliances, on energy consumption and carbon emissions. Participants explore the immediate and long-term effects of these actions on the environment, particularly in relation to power generation and fossil fuel use.
  • Some participants question whether turning off lights has any immediate benefit, arguing that the fossil fuels have already been burned and carbon dioxide released into the atmosphere.
  • Others suggest that while individual actions may seem negligible, collective behavior (e.g., many people turning off lights) can influence power plant operations and reduce fossil fuel consumption.
  • One participant notes that the averaging process in electricity demand means individual actions are not directly measurable by power plants, but significant changes in collective behavior can lead to adjustments in power generation.
  • There are discussions about the types of loads (resistive vs. inductive) and how they affect power generation and grid stability.
  • Some participants highlight the complexity of the power grid, including the roles of different energy sources (coal, gas, hydro, nuclear) in responding to demand changes.
  • Concerns are raised about the flexibility of various power sources and how they adapt to changes in demand, questioning whether reducing consumption leads to a decrease in fossil fuel combustion.
Participants express a range of views, with no consensus on the immediate benefits of turning off lights. While some acknowledge the potential for collective action to influence power generation, others emphasize the complexities of the energy grid and the types of power sources involved.
The discussion includes technical details about power generation, grid stability, and the characteristics of different energy sources, which may not be fully resolved or agreed upon by participants.
esmeralda4
Hi,
Got into a discussion at School today about reducing energy consumption at home in order to save the planet.
I asked a question that stumped my Physics teacher.
If I do turn off my lights and TV when I'm not in the room surely the fossils fuel would have already been burn and the carbon dioxide therefore already released into the atmosphere? I understand that Power Stations rely heavily on predicting the electricity demand and so if we all started being more energy efficient they would start burning less fossil fuels - but my question is this... Actually turning off a light switch does that have any 'immediate' benefit to the planet? Does it really make a difference? Surely all we are doing is not using electricity that has already been produced?
Thanks!
Science news on Phys.org
esmeralda4 said:
Hi,
Thanks!
There is an averaging process that goes into electricity demand. Your individual act will never be known by the power plant operators. If, however, 20% of the people on that grid turn out unused lights, the power plant sees that and adjusts it's output accordingly. But, keep in mind that almost all grids have many, many power plants, of differing types with differing response times.
If you did not use the electricity, where would it go?
Though small changes like that are too small to measure, every change does have a real effect at the turbine.
This is kind of like one person not voting because they think one vote wouldn't make a difference.
I heard (on the radio?) that the methane generated by cattle has more greenhouse effect than all the carbon dioxide we produce from combustion. Is this accurate?
I can only say that I have stood in a stable filled with farting cattle and I have stood at an open sampling port on a coal-fired power plant flue. I'll take the cows every time.
No, but it is significant, mainly because methane is a much worse greenhouse gas than CO2.
However, methane is not stable once it is in the atmosphere; it breaks down into water and CO2 (I don't remember the half-life, a few months?) meaning it does not accumulate in the atmosphere in the same way as CO2 from combustion.
Back to physics and the original question - I don't really know much about this, but I think that the effect of the load reductioin on the generator is smoothed out by the changes in the fields induced around the power lines and around the coils in the generator itself. Also, the power grid has large capacitors to smooth out voltage changes. The effect of large load changes also depends on the type of load - resistive loads (like light bulbs, heaters, etc) have a different effect than inductive (or reactive) loads (large industrial - sized motors) that generate magnetic fields as they operate. Try Googling "megawatts" and "megavars."
But even with this "smoothing" effect, there really isn't anywhere for the "power" to go except to the loads, since increasing magnetic fields eventually shrink (when your neighbor turns her light on...) and the energy is pumped back into the line, raising voltage.
Turning off the lights will reduce your power bill and will reduce the amount of electric power produced by the plant. I will leave the morality of voting or not, and the effects of farting cows to other posters.
esmeralda4 said:
Hi,
Thanks!
It wouldn't have an immediate benefit because power plants need to keep electricity generation equal to demand. In most plants it takes hours to increase generation load, with the exception of hydroelectric, so they need to predict what the demand will be. This is why on usual hot days, you may experience power outages from people turning on their AC.
An increase in the load reduces the system voltage, so if the generation rate is not increased, the new load will be satisfied by essentially stealing a little bit of the energy that was going to everyone else. If this goes on too long, it's a "brownout," if it goes too far the system protection features will trip the low voltage section off. That's when you see a "power outage" from high demand. In the normal case of small variations, the generator voltage regulator acts continuously to restore the voltage by adjusting the field strength in the generator. The plants have control systems to increase the flow of coal or gas to the boiler to increase the power output. Nuclear units do this "by themselves" due to the negative reactivity feedback (but in practice, the nukes are run continuously at full power because the fuel is the cheapest, and the controls systems won't let the demand drive power above the rating of the plant). Maybe a real EE out there can expand / correct this.
As others have pointed out, in the grid, production must balance EXACTLY consumption to a few seconds precisely, because of conservation of energy. So, yes, if you turn off your lights, you will consume a little bit less, and hence, the produced power must also be a little bit less.
However, the real question is: *what source* will adapt ? Will it be a coal-fired plant, that is not very flexible ? Or will it be a gas turbine, that is very flexible ? Or will it be hydropower that is very flexible ? Will it be a nuclear power plant that can or cannot be flexible depending on its steering mode ? Will it be wind energy ?
The point is, for instance, that if one regulates the fast changes with hydro, then this has no effect at all on the overall CO2 production and fossil fuel combustion. Same if it is wind energy or nuclear that adapt to the changes.
This is BTW one of the silly things with the wind energy in Denmark. Because wind energy is highly variable, the Danes use their neighbours the Swedes to act as a buffer. Now, Sweden is essentially 50% nuclear and 50% hydro, where they use their hydro to adapt to load changes and nuclear provides base load. So when the wind blows in Denmark, the Danes take a bit of this current, and sell a large fraction of it to Sweden, which buys it, and cranks down its hydro. When the wind drops in Denmark, the Danes buy back their electricity from the Swedes, which now boost up their hydro. So the Danish wind turbines trade essentially electricity with the Swedish hydro: the more it blows in Denmark, the less the Swedish use their hydro.
Now, of course there is a net benefit in CO2 production, but it is far less than the total wind production in Denmark.
Don't forget that some markets actually do store their excess power, e.g., by pumping water up a mountain. Of course, this can be problematic if the reservoir breaks.
  • · Replies 76 ·
13K
  • · Replies 20 ·
  • · Replies 130 ·
17K
