Complex Anal. Problems: Need Help!
The discussion revolves around two problems in complex analysis: the convergence of the series ∑z^n for |z|<1 and the nature of the singularity at z=1 for the function f(z)=1/√(z-1). Participants express confusion regarding the definitions and properties related to uniform convergence and types of singularities.
  • Some participants argue that the series ∑z^n is not uniformly convergent, suggesting that applying the definition of uniform convergence clarifies this point.
  • Others assert that the singularity at z=1 for f(z)=1/√(z-1) is a pole, citing the definition that a pole exists if the function can be expressed as f(z) = g(z)/(z-a)^n for some holomorphic g.
  • A participant questions the classification of the singularity, noting that if g(1)≠0 is required for a pole, then the function cannot be expressed in that form, leading to confusion.
  • Another participant challenges the earlier claims by stating that both poles and essential singularities require the function to be holomorphic on a deleted neighborhood of the singularity, which f(z)=1/√(z-1) does not satisfy.
Participants express differing views on both problems, with no consensus reached regarding the uniform convergence of the series or the nature of the singularity at z=1.
Participants reference definitions and properties from complex analysis, but there are unresolved questions about the application of these definitions to the specific cases discussed.
matheater
I have the following problems
(1)Consider the series ∑z^n,|z|<1 z is in C
I thik this series is absolutely and uniformly comvergent since the series ∑|z|^n is con vergent for |z|<1,but I have a book saying that it is absolutely convergent,not uniformly...i am confused...
(2)for the function f(z)=1/√(z-1),z=1 is a (a)pole (b)an essential singularity ?
I think it is an essential singularity since if it is a pole,say of order m then m is a positive integer and we can write f(z)=g(z)/(z-1)^m, where g(z) is analytic at z=1 and g(1)≠0,
but the given function cannot be written in this way,but the answer is given pole,i am again confused...
Can anybody help me?
1) It is indeed not uniformly convergent. You really just have to apply the definition of uniform convergence to see it.
2) It is a fact that a singularity is only an essential singularity if and only if the limit does not exist and it is not infinity. The definition of a pole is we can write f(z) = g(z) / (z-a)^n, for some holomorphic g, and the order of the pole is the smallest n for which this is true. If f(z) = z^-1/2, then this is satisfied by taking g(z) = z^1/2 and n = 1.
Thank u very much for your kind help,but I couldn't understand the second answer,will u please explain it a bit more ?
I don't know what more I can do but restate what I wrote before. I don't have my complex analysis book with me right now, but wikipedia define a pole as follows:
Suppose f has a singularity at x = a... If there exists a holomorphic function g(z) so that we can write
[tex]f(z) = \frac{g(z)}{(x-a)^n}[/tex], then a is a pole of order n, where n is the smallest number for which f can be written like this.
Now consider [tex]f(z) = z^{-\frac{1}{2}}[/tex], which has a singularity at z = 0. We can write
[tex]f(z) = \frac{z^ {\frac{1}{2}}}{z}[/tex]
Therefore z=0 is a pole of order 1.
but g(0)=0,how is this satisfying the criteria for being a pole?
Hmm this is true... I retract my answer, and hope someone else can help you.
Neither. Both poles and essential singularities require the relevant function to be holomorphic on a deleted neighborhood of the singularity. [tex]z^{-\frac{1}{2}}[/tex] isn't even continuous on one of these neighborhoods. In descriptive terms, however, it would look like half of a simple pole stretched around.
