Can you solve the n-dimensional sphere packing problem?
  • Context: Graduate
  • Thread starter Thread starter Dragonfall
    Sphere
The discussion centers around the n-dimensional sphere packing problem, specifically regarding the packing of n-dimensional unit vectors from \mathbb{C}^n under certain inner product constraints. Participants explore the implications of these constraints and the relationship to sphere packing in various dimensions, including potential generalizations and limiting cases.
  • One participant questions whether the problem truly reduces to a sphere packing problem, indicating uncertainty about the formulation.
  • Another participant notes the difficulty of commenting without specifying the set and expresses unfamiliarity with extending sphere packing concepts to complex numbers.
  • A participant discusses how the maximum size of the set is dependent on the parameter δ, with specific cases outlined for δ = 0 and δ = 1.
  • One participant proposes a limiting case in R^3, discussing how to space unit vectors on the unit sphere while maximizing angles between them, and describes configurations for small numbers of vectors.
  • The same participant suggests that for a large number of vectors, the tips of the vectors can be uniformly distributed on the sphere's surface, leading to equilateral triangles in the triangulation of the sphere.
  • Another participant inquires whether the greedy algorithm used in the limiting case produces an optimal packing of unit vectors.
  • A subsequent reply posits that the greedy algorithm may be optimal, but emphasizes the need for a rigorous proof regarding the equilateral nature of the triangles formed in the limit.
Participants express various viewpoints and uncertainties regarding the formulation of the problem, the implications of the inner product constraints, and the effectiveness of the greedy algorithm. No consensus is reached on the optimality of the packing or the reduction to a sphere packing problem.
There are limitations in the discussion regarding the assumptions made about the set of vectors and the extension of concepts from real to complex numbers. The mathematical steps and proofs required to establish optimality or the nature of the packing remain unresolved.
Dragonfall
How many n-dimensional unit vectors from [itex]\mathbb{C}^n[/itex] can you pack in a set such that for any two vectors, [itex]\left<a, b\right>\leq\delta[/itex] for some delta between 0 and 1?
(<a,b> denotes the inner product).
This reduces to packing of n-2 dimensional spheres on a n-1 dimensional sphere, if that helps.
EDIT: on second thought I'm not sure if this reduces to a sphere packing problem.
Mathematics news on Phys.org
Anyone?
Without specifying what the set is, it's hard to comment. Also, I've only ever seen sphere packing conisdered for real numbers; not sure how the extension to complex would play out...
The max size of the set depends only on [itex]\delta[/itex], which determins how close two vectors from the set can be. [itex]\delta =0[/itex] then the max size is the dimension; [itex]\delta =1[/itex] then it's infinite.
EDIT: I made a typo in my first post. The requirement is that
[tex]\left|\left< a,b\right>\right| \leq\delta[/tex]. Note the modulus operator.
Anyone?
Supposing we restrict it to R^3 and are interested in the limiting case where delta -> 1. Obviously this is not your full problem, but at least I can say something about it, whereas the full out problem seems pretty hard. What I say can be generalized to R^n as well.
Suppose you are adding unit vectors one by one, trying to keep their tips spaced as far apart as possible on the unit sphere (or equivalently, trying to keep their angles as big as possible for a given number of vectors). For 2 vectors, you would place them at antipodes (opposite points on the sphere), 180 degrees. For 3 vectors, 120 degrees in the plane. 4 vectors, tetrahedron (~109 degrees). 5 vectors, a more complicated shape, 12 vectors, the points on a dodecahedron, etc etc.
For small numbers of vectors, adding each additional vector causes massive changes in the configuration of all previous vectors, and the angle jumps drastically (180 -> 120 -> 109 ..). However, when there are already a ton of vectors on there, say, 100, then the ball looks like a prickly sea urchin, and if you add one more vector, then the other vectors on there can accommodate it by all shifting very slightly. Everything from now on is assuming a large number of vectors.
Thus for large numbers of vectors, the the surface area of the unit sphere is uniformly sprinkled by the different vector tips. Further, if the vector tips are used to triangulate the surface of the sphere (Delaunay triangulization would work nicely), then as the number of vectors becomes large the triangles will become approximately equilateral.
You can use the Euler characteristic to find that the number of triangular faces is f=2(v-2) where v is the number of vectors. (v-e+f=2, and e=3f/2 since each face has 3 edges, which would double count each edge)
Since the triangles take up roughly equal surface area on the sphere, f*A = 4*pi, or A = 4*pi/f where A is the area of a single triangle. Additionally, since the triangle is approximately equilateral, the area is related to the edge length by A = d^2*sqrt(3)/4, or d = sqrt(4A/sqrt(3)).The angle between 2 neighboring vectors is then θ ~= arcsin(d) ~= d for small angles.
Putting this all together,
in the limit as v-> infinity, θ = sqrt(4*(4*pi/2(v-2))/sqrt(3))
You can invert this and find
in the limit as θ -> 0, v = 8*pi/(sqrt(3)*θ^2) + 2
assuming I didn't make any algebra mistakes in there...
your delta, by the way, is cos(θ), as that is the way the inner product relates to angle.
If I understood correctly, you gave an approximate answer in the limiting case using a greedy packing algorithm. That's interesting. Do you know whether the greedy algorithm in this case will produce an optimal unit vector packing?
I think it is optimal. To be rigorous, you would have to prove that: given an optimal packing algorithm, the delaunay triangulization (or any other triangulization) of the configuration will produce triangles that approach equilateral triangles in the limit as θ -> 0.
If there are multiple optimal packing algorithms aside from rotations of the original algorithm (I doubt it), then you only need to prove it for one algorithm.
