| Thread Closed |
How can i generate electricity with out any feul |
Share Thread |
| Jun7-08, 04:07 PM | #1 |
any body helps me that how can i generate electricity 12volts DC or give me idea to run car generater for 12 Volts Dc and then i converts it through UPS in 220Volts AC but there is big problem that how can i opreate or run car generater (with out any feul tecnology or wind and water) teel other source or technique to run generater i need only 500 to 1000 watts so please help me
Thanks My name is Hadi Bux I M from Pakistan send me email or this forum panhwar2008@yahoo.com |
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| Jun8-08, 01:32 PM | #2 |
Mentor
Well, you certainly need some kind of energy source. That 1000 watts has to come from somewhere. Solar maybe? With a bicycle setup, you can generate about 100W yourself for a while, depending on what kind of physical shape you are in....
| Jun8-08, 02:41 PM | #3 |
Mentor
I don't understand what is actually needed. 12 Vdc or 220 Vac?
Does it need to be portable? Carried by hand, or sitting in the car? Or is this for backup when the electricity goes out in the house? How long must the device operate? A car battery might last about an hour at 500-1000 W, then it would need recharging before it can be used again. More information about the application and requirements are likely to get a better answer. |
| Jun11-08, 03:37 AM | #4 |
i need 12V DC but the method is cheepest how it is possible or how can i do it to make cheepest generetor to generate 12v dc volts
So please any friend knows please tell me |
| Jun11-08, 06:49 AM | #5 |
Mentor
You didn't say where you would be using this (in the home? in a car? outside of a home or car?), but here are some ideas:
In the home, a 12 Vdc converter that plugs into a wall outlet. In a car, a simple cord that plugs into the cigarette lighter. Outside of home & car, a 12V rechargeable battery. Get one just big enough to provide your required current or power. |
| Jun11-08, 09:50 AM | #6 |
There's several designs out there to run a battery charger from a bicycle hooked up to a car's alternator. Most people can generate about 100W for several hours using this method - maybe up to 300W if you are in really good shape. If you really need up to 1000W, then you'll have to pedal for several hours to charge up some batteries before you can use the stored energy.
Here's one example, a 150W pedal powered generator: http://www.scienceshareware.com/buil...iner-stand.htm |
| Jun16-08, 04:34 AM | #7 |
any other power generating method for cheep cost i m from pakistan
| Jun16-08, 06:50 AM | #8 |
Mentor
Where will you be using it? What are you using it for?
A 12 Vdc converter that plugs into a wall outlet is fairly inexpensive, at least in the USA (about 20 to 30 $US here). But you would be restricted to using it in the home or places where there is a regular 220V wall outlet. |
| Jun17-08, 12:15 AM | #9 |
Mentor
Wait, there is a problem with these 12 Vdc converters. They typically run 10 Watts or perhaps even 30 Watts, but you said you want 500 to 1000 W.
Power supplies with 12V and 500-600 Watts seem to cost about 130 to 140 $US: http://accessories.us.dell.com/sna/p...322&lid=680419 http://www.tigerdirect.com/applicati...RqCjCVRqCjCVRq I don't know if that price is something you can afford, and where in Pakistan these would be available. |
| Jun17-08, 04:29 AM | #10 |
friends you cant under stand me i need 12 V DC out put i m from very poor area of pakistan there is electricity but fluctuation of light in our country there is very big problem in 24 hours a day electricity is present onlt 10 hours and 14 hours power fells so i need some low cost idea that i generate 12V DC power with out any feul that can charge battery and i use UPS to convert 12V DC to 220V AC ok.
| Jun17-08, 04:43 AM | #11 |
The answers you've already been given are pretty good.
You can't generate electricity without some energy input. Can you use the sun? Wind? Hydro? An engine? Human power? 500-1,000W is a large amount of energy to be expecting from nothing. You can't get it from nowhere. |
| Jun17-08, 08:20 AM | #12 |
Mentor
Hadi, thank you for explaining the situation more fully.
One option might be to get a larger capacity battery for the UPS. I don't know how easy it would be to replace the battery in the UPS unit with a large car or truck battery to your UPS. If you're somewhat handy with electronics it should be possible. You might also need a separate battery charger, with which you would charge the battery during the time power is on. Of course, there is a lot involved with that approach, and a gasoline-powered generator might be the easiest solution after all. I think the solution, if there is one, will not be very cheap. Regards, Mark |
| Jun17-08, 09:08 AM | #13 |
Here in India, we have so called "Inverters" which use large vehicle batteries. Most houses here use these, as they are relatively cheap (compared to gasoline-run generators) and quite a life-saver during the monsoons.
Battery output around 14V DC and is converted to 240V AC by an additional unit. They cost between Rs 3000 and Rs 5000 approximately (around 100$). These can supply around 1000W for a period of 4-5 hours. Gasoline powered generators could cost almost double that, and maintenance would be high due to obvious reasons today. I am sure these must be available in Pakistan cities as well. If you have friends in cities, you can ask them about these devices. Solar generators would be nice in tropical regions, if only they could work at night! Maybe a strong battery unit would hold for a night, but then again initial costs are too high. Same for wind. |
| Jun17-08, 10:13 AM | #14 |
Do you have friends, family, or neighbors that can help or supply things, maybe even a scrap yard that might have items you can use. Thanks to "Google Earth" I passed over your place this morning ![]() there are a few places in Pakistan that have picture coverage, and we can see the terrain quite clearly. It's getting to be a great world to live in. I know you have air to work with, and if you have any source of natural gas, you might be close to some possibilities. Hope to hear from you again. Ron |
| Jun17-08, 01:31 PM | #15 |
is this possible that to opreate generators on biogas if yes then please inform me in detail
thanks. |
| Jun18-08, 04:34 AM | #17 |
Here's a popular brand's website http://www.su-kam.com/inverters.html |
| Thread Closed |
Similar discussions for: How can i generate electricity with out any feul
| How do space shuttles generate electricity? | General Engineering | 3 | ||
| Ways to generate clean electricity? | General Physics | 6 | ||
| is it plausible to generate electricity through buoyancy? | General Engineering | 13 | ||
| New ways to generate electricity ? | General Physics | 4 | ||
| Pollution-free way to generate electricity | Computing & Technology | 4 | ||
