| Thread Closed |
Joint Distribution (easy qn) |
Share Thread | Thread Tools |
| Jun11-08, 04:53 AM | #1 |
The following table gives the joint probability mass function (p.m.f) of the random variables X and Y. http://img170.imageshack.us/img170/555/tableph9.jpg Find the marginal p.m.f's [tex]P_X \left( x \right)[/tex] and [tex]P_Y \left( y \right)[/tex] 2. The attempt at a solution I think I have just missed the point of this somewhere. I know that: [tex]{P_X \left( x \right) = \sum\limits_{all\;y} {P_{X,Y} \left( {x,y} \right)} }[/tex] and [tex]{P_Y \left( y \right) = \sum\limits_{all\;x} {P_{X,Y} \left( {x,y} \right)} }[/tex] I just don't know how to apply this to the question properly. For [tex]P_X \left( x \right)[/tex] it's the sum of [tex]{P_{X,Y} \left( {x,y} \right)}[/tex] over all y (y=0,1,2). So do we just take the first row? i.e. 0.15+0.20+0.10 = 0.45? Following this, would [tex]P_Y \left( y \right)[/tex] be 0.35? Any help would be greatly appreciated. Cheers |
| Jun11-08, 09:09 AM | #2 |
Hello,
The possible X values are x=0 and x=1, so if you compute [tex]P_x \left( 0 \right) = p(0,0)+p(0,1)+p(0,2)=X1[/tex] Find x1 [tex]P_x \left( 1 \right) = p(1,0)+p(1,1)+p(1,2)=X2[/tex] Find x2 *You basically do this for how many possible X values you have. Then the marginal pmf is then [tex]P_x \left( x \right) = \left\{ x1forx= 0; x2forx=1;0,otherwise} [/tex] Then compute the marginal pmf of Y obtained from the column totals. Hope that makes sense. |
| Jun11-08, 09:25 AM | #3 |
thanks for your response :)
So I should define the marginal pmf's as? [tex] P_X \left( x \right) = \left\{ {\begin{array}{*{20}c} {0.45\;...\;x = 0} \\ {0.55\;...\;x = 1} \\ \end{array}} \right. [/tex] [tex] P_Y \left( y \right) = \left\{ {\begin{array}{*{20}c} {0.35\;...\;y = 0} \\ {0.3\;...\;y = 1} \\ {0.35\;...\;y = 2} \\ \end{array}} \right. [/tex] |
| Jun11-08, 09:30 AM | #4 |
Yes, that's correct. From what I've been taught, you also have to put {0 otherwise} but depending on how the notation that you've been taught in class/book, then it's fine.
Also, for the marginal pmf of Y you can also put for {.35 y = 0,2 . Again, a notational way to write it. |
| Jun11-08, 09:46 AM | #5 |
Yep sure, that makes sense, thanks for your help!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Joint Distribution (easy qn)
| Joint Bivariate Exponential Distribution | Calculus & Beyond Homework | 1 | ||
| Joint/Conditional distribution | Calculus & Beyond Homework | 0 | ||
| Joint Distribution of Changing Mean | Set Theory, Logic, Probability, Statistics | 6 | ||
| Joint Distribution Question | Set Theory, Logic, Probability, Statistics | 3 | ||
| How to visualize joint uniform distribution | Set Theory, Logic, Probability, Statistics | 2 | ||
