Anyone determine what the definition/properties of this bolt
  • Thread starter Thread starter bbrees
    Bolt
The discussion revolves around the definition and properties of a specific bolt described as 3/4 x 4 CS-N-LW. Participants explore various interpretations of the specifications and potential applications of the bolt.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants note that a 3/4-4 specification indicates a coarse thread, but question whether it aligns with the UN series thread standards.
  • There is a query about the context in which the bolt is used, suggesting that its application might clarify its specifications.
  • Some participants propose that the "4" could imply a military specification or relate to rebar dimensions.
  • One participant suggests the possibility of it being an ACME thread, particularly in lead or ball screws, noting that 4 turns per inch are common.
  • Another participant questions whether the description could refer to a vacuum fitting instead of a traditional bolt.
  • Concerns are raised about the typical thread pitch for a 3/4" bolt, with one participant indicating that it usually starts at 5 TPI.
Participants express multiple competing views regarding the specifications and potential applications of the bolt, indicating that the discussion remains unresolved.
There are limitations regarding the assumptions made about the thread types and applications, as well as the lack of specific context for the bolt's use.
bbrees
Anyone determine what the definition/properties of this bolt is?
3/4 x 4 CS-N-LW
a 3/4-4? That's one coarse thread. It's definitely not a UN series thread. Can you tell us what context you are seeing this callout? What is it used in, etc...
Thats what I thought, is there an alternate way of specifying threads in the US? Does 4 on it's own imply MIL?
Or it could be rebar,thats about 3/4-4!
Could it be an ACME thread? Lead or ball screws with 4 turns per inch are pretty common. The CS-N-LW could just be the manufacturer's material & finish specifications.
Do you actually have one of these or just the description? If just the description, is there any possibility that this refers to a vacuum fitting?
I too thought about that, but, from what I saw, 3/4" starts at 5 TPI.
