Understanding the Electric Field of a Plane Wave: A Complex Vector Approach
The discussion focuses on calculating the electric field of a plane wave using complex vector representation. The formula for the electric field at a distance s from a reference point is given by E(s) = E(0) * exp(-jks), where k is the wave number defined as 2 * PI / wavelength. The user seeks clarification on multiplying complex numbers with vectors and concludes that the instantaneous electric field can be represented as Re{EM(0) * exp(-jks)}. The discussion emphasizes that both EM(0) and exp(-jks) are complex numbers, allowing for valid multiplication.
  • Understanding of complex numbers and their operations
  • Familiarity with electromagnetic theory, specifically electric and magnetic fields
  • Knowledge of wave mechanics, including wave number and wavelength
  • Proficiency in vector mathematics, particularly in 3D vector representation
  • Study the mathematical properties of complex vectors in electromagnetic fields
  • Learn about the physical interpretation of real and imaginary components in wave equations
  • Explore the application of Fourier transforms in analyzing wave phenomena
  • Investigate numerical methods for simulating electromagnetic fields in programming environments
Students and professionals in electrical engineering, physicists working with electromagnetic theory, and software developers involved in simulations of wave phenomena.
broli86
Hi I've working on a computer program where I need to calculate some
electric fields. I am referring to a thesis which provides these
formulas. For eg:
The electric field for a ray(plane wave actually) at a distance s from
the reference point:
where E(s) = electric field at a distance s from the reference point.
E(0) = electric field at reference point.
s = distance travelled.
k = wave number = 2 * PI / wavelength
exp(-jks) as per my thesis, represents the phase variation of the
electric field along the ray.
now, electric field is always a vector(3d in my case). so the user
will input a magnitude for the electric field at the reference point
and i can calculate the reference electric field vector[ E(0) ] easily
by multiplying it with the unit direction vector the wave.
exp(-jks) expands as
cos(ks) - j sin(ks)
if E(0) is a vector of the form a x + b y + c z,
Then E(s) = (a x + b y + c z) * ( cos(ks) - j sin(ks) )
I'm really confounded at this expression because how does one multiply
a complex number and a vector ? And even if it is possible then what
about E(s) ? If E(0) was defined to be a 3d vector then E(s) must also
be a 3d vector. What does it actually mean ? If there are some EE/
physics experts who can probably figure it out then it would be really
great.
Well really E(s) = Re{Eo * exp(-jks)} (ie the real part)... so in short you're supposed to ignore the sin term.
I think that equation was somewhat wrong. I think the EM field can be represented as a complex vector:
A complex vector as in a 3d vector whose components are complex
numbers :
(a1 + i * b1) xhat + (a2 + i * b2) yhat + (a3 + i * b3) zhat
where xhat, yhat, zhat are unit vectors along x, y, z respectively.
one can rearrange it to get real part as the electric field vector and
imaginary part as the magnetic field vector, both at right angles to
each other :
real + i * imag
electric field: (a1 * xhat + a2 * yhat + a3 * zhat)
magnetic field: (b1 * xhat + b2 * yhat + b3 * zhat)
instantaneous electric field: Re( EM(0) * exp( -jks ) )
instantaneous magnetic field: Imag( EM(0) * exp(-jks) )
where k (wave number ) = 2 * pi / wavelength
s = distance traveled in the direction of the plane wave
EM(0) is the EM field at reference point.
Here it seems the problem won't arise while multiplying EM(0) and exp(-jks) as both are complex numbers.
Is this correct ??
  • · Replies 17 ·
  • · Replies 22 ·
