How Does Water Pressure Change with Column Height and Diameter?
The discussion revolves around understanding how water pressure changes with the height and diameter of a vertical column of water. The original poster seeks clarification on the calculation of water pressure at the base of the column, particularly focusing on the effects of varying heights and diameters.
  • Participants explore the relationship between pressure and the weight of the water column, with one participant providing a formula for pressure based on height, density, and gravity. There are also questions about the appropriate symbols used in the calculations.
The discussion includes attempts to derive the pressure formula and clarify terminology. While some participants provide insights and corrections, there is no explicit consensus on the best approach or understanding of the problem.
There is a suggestion that the original poster may not have attempted the problem before asking for help, which raises questions about the expectations for homework assignments.
mjp42@csufresno.edu
Explain why pressure increaseds beneath a vertical column of water and how to calculate water pressure ate the base of the column. Include the effect of varying heights and column diameters.
thanks
mike
This sounds suspiciously like a homework assignment.
It also sounds suspiciously as though you haven't even attempted it -- the answer is simple and should be easy to find in any first-year physics textbook.
- Warren
The pressure is based on the weight that must be supported at the given depth. The volume of a the cylinder is just area * height
[tex]v =ah[/tex]
Now you find the mass of the water which is just density * volume. I don't remember the symbol for density so I'll just use D.
[tex]m = vD[/tex]
[tex]m = ahD[/tex]
Now add gravity
[tex]F = ahDg[/tex]
Now find the pressure on the bottom of the cylinder by dividing by the area
[tex]P = hDg[/tex]
There you have it, the pressure at a given depth is height * density * gravity.
The normal symbol for mass density is [itex]\rho[/itex] :smile:
- Warren
  • · Replies 16 ·
