What are the Eigenvalues and Eigenfunctions of the Sturm-Liouville Problem?
  • Thread starter Thread starter EngageEngage
The discussion revolves around finding the eigenvalues and eigenfunctions of a Sturm-Liouville problem defined by a second-order differential equation with specific boundary conditions. The problem involves analyzing the behavior of the function under different values of the parameter λ.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the characteristic polynomial and the general solution to the differential equation. They raise questions about the implications of boundary conditions, particularly the behavior of the hyperbolic cosine function and its roots. There is also discussion about handling different cases for λ, including positive, negative, and zero values.
Some participants have provided guidance on specific steps, such as setting certain constants to zero based on boundary conditions. Multiple interpretations of the problem are being explored, particularly regarding the implications of different values of λ on the solutions.
Participants are considering the implications of boundary conditions and the nature of the solutions for various cases of λ, which may lead to different forms of eigenfunctions. There is an acknowledgment of potential confusion regarding the roots of the hyperbolic functions involved.
EngageEngage
Find the eigenvalues and the eigenfunctions of the Sturm-Liouville problem
[tex]\frac{d^{2}u}{dx^{2}}=\lambda u[/tex]
[tex]0<x<L[/tex]
[tex]\frac{du}{dx}(0) = 0[/tex]
[tex]u(L) = 0[/tex]
characteristic polynomial:
[tex]p^{2}=+-\lambda[/tex]
[tex]u = Ae^{\sqrt{\lambda}x}+Be^{-\sqrt{\lambda}x}[/tex]
[tex]u = Ccosh(\sqrt{\lambda}x)+Dsinh(-\sqrt{\lambda}x)[/tex]
Now, i try to solve the boundaries:
[tex] \frac{du}{dx}(0)=-D\sqrt{\lambda}cosh(-\sqrt{\lambda}x)=0[/tex] ... I am confused now because cosh doesn't have a root unless its translated. Can anyone help me out with this please?
Hi EngageEngage!
Isn't it just D = 0? :smile:
O yeah, thanks. not sure how i managed to screw that up. then I get
[tex]u = Ccosh(\sqrt{\lambda x})[/tex]
[tex]u(L) = 0 = Ccosh(\sqrt{\lambda L})[/tex]
But cosh has no root here so, i get u = 0, by setting C = 0.
I just realized it: i probably have to do this with lambda>0, <0 and = 0, is that righT?
so when: [tex]\lambda = 0[/tex]
[tex] u = C(1)+D(0);;;<br /> u = C[/tex]
and then i get u = 0 again.
now when [tex]\lambda <0[/tex]
[tex]u = Ae^{i\sqrt{|\lambda|}x}+Be^{-i\sqrt{|\lambda|}x}[/tex]
[tex]u = Ecos(\sqrt{\lambda}x)+Fsin(\sqrt{\lambda}x)[/tex]
[tex]u'(0)=0 when F = 0[/tex]
[tex]u = Ecos(\sqrt{\lambda}x)[/tex]
[tex]u(L)=0=Ecos(\sqrt{\lambda}L)[/tex]
[tex]\lambda = (\frac{(n-\frac{1}{2})\pi}{L})^{2}, n = 1,2,3...[/tex]
[tex]u = cos(\frac{(n-\frac{1}{2})\pi x}{L})[/tex]
is that right?
messed that last part up, but i got it now. Thanks!
Hi EngageEngage! :smile:
Yes, that looks fine!
(though personally I don't like minuses, so I'd write it:
[tex]u = cos\left(\frac{(n+\frac{1}{2})\pi x}{L}\right)[/tex] )
(note the \left( and \right) in the LaTeX! :smile: )
  • · Replies 18 ·
  • · Replies 105 ·
13K
