Can I Prove Perpendicular Acceleration Using d(v^2)/dt = 0?
  • Thread starter Thread starter LD_90
    Acceleration
The discussion revolves around proving that the acceleration of a particle moving at constant speed is perpendicular to its instantaneous velocity. The original poster seeks clarification on using the equation d(v^2)/dt = 0 as a method for this proof.
  • Participants explore the validity of using the derivative of speed squared to demonstrate the relationship between acceleration and velocity. Some suggest that a more physical argument might be preferable to a purely mathematical approach.
There is an ongoing exploration of different arguments, including mathematical and physical perspectives. One participant has provided a detailed reasoning based on Newton's second law, which has resonated with others in the discussion.
Participants are navigating the balance between mathematical rigor and physical intuition in their arguments. The original poster expresses some uncertainty about the approach being taken.
LD_90
The acceleration of a particle moving at constant speed is perpendicular to its instantaneous velocity. How can I show this by using the fact that
d(v^2)/dt=d(v. v )/dt=0?
This doesn't seem like the most direct way to look at the concept. Help me out.
I think that it is, indeed, the most direct way, since you utilize the sole information you have been given, namely that the speed is constant.
Since the speed is constant, you have the equation d/dt(v^(2))=0 immediately at your disposal.
I've thought a bit more of your complaint; possibly you would prefer a more
"physical" argument, rather than what perhaps seems like mathematical "trickery" and "waving with the magic wand".
So, I'll give a second argument, based on Newton's second law:
(Forgive me for not "LATEX"-ing the code, I'll use the symbol "." for the dot product in the remainder)
Newton's second law states:
F=ma
Form the dot product:
F.v=ma.v
Integrate this from 0 to an arbitrary T:
int(0 to T)F.vdt=1/2mv^(2)(t=T)-1/2mv^(2)(t=0)
Since the speed is given as constant in time, we necessarily have:
int(0 to T)F.vdt=0, for ARBITRARY CHOICE OF T!
This means, that we necessarily have F.v=0 for all times!
Or, going back to Newton's 2 law again:
0=ma.v-->a.v=0, a is perpendicular on v
Thank you arildno. It all clicked after I read your first post.
  • · Replies 42 ·
  • · Replies 27 ·
