Why Assume Potential Only in the x Direction in Electrostatics BVP?
  • Thread starter Thread starter zigggggy
    Electrostatics
The discussion focuses on the assumption of electric potential variation only in the x-direction within a boundary value problem (BVP) involving a dielectric enclosing a volume charge. Participants clarify that this assumption is valid when considering the symmetry of the system, particularly when the charge distribution is uniform and the plates are effectively infinite in the y and z dimensions. The application of Gauss's law is emphasized as a method to derive the electric field, with specific reference to the symmetry of the setup aiding in simplifying calculations.
  • Understanding of electrostatics and electric potential
  • Familiarity with Gauss's law and its applications
  • Knowledge of boundary value problems in electrostatics
  • Concept of symmetry in electric fields and charge distributions
  • Study the derivation of electric fields using Gauss's law in various geometries
  • Explore the concept of electric potential in systems with uniform charge distributions
  • Investigate boundary value problems in electrostatics with different charge configurations
  • Learn about the implications of symmetry in electrostatic problems and how it simplifies calculations
Students and professionals in physics, particularly those studying electrostatics, electrical engineers, and anyone involved in solving boundary value problems related to electric fields and potentials.
zigggggy
http://stashbox.org/138351/Image-24.png
http://shup.com/Shup/45816/Image-25.png
As you can see, this is an example problem from my text. I'm looking for some clarification in their decision to assume potential exists only in the x direction. Specifically, I don't understand why they assumed the potential only varies in the x direction when the dialectric encloses a volume charge. I know when the charge is a surface charge on parallel plates with surface Area >> than the distance between them, we can assume the plates are of infinite size and so the electric field between them is normal to the surface. But here, the plates are BOTH at a potential of 0 V and the enclosed charged is a volume... So I'm hoping someone can elaborate on this.
I was also hoping someone can help me understand how they are using Gauss's law in exercise 5.1 to solve for the electric field. I tried many ways to solve it and I don't always get the answer they do. I'm thinking that you use the E-field found in the example to find E(x) at x=0 and x=d?
Thanks.
First, let's say you had a uniformly charged insulator that was arbitrarily large in all 3 directions. Would there be any potential in it? Why (not)? Now think about what happens if it's only arbitrarily large in y and z, but in x has some finite width.
As for the exercise, you don't need anything from the example to find the electric field. Just put your Gaussian "pillbox" so that two of its faces are just outside the plates, note that the system has a symmetry in the x-direction, and use as directed :)
  • · Replies 69 ·
