Combining Laser Beams: Calculating the Optimal Wavelength | Expert Tips
  • Context: Undergrad
  • Thread starter Thread starter engalaanabil
    Beam
The discussion revolves around the calculation of a new wavelength when combining two coherent laser beams with known wavelengths. Participants explore the implications of combining laser beams, particularly in the context of diffraction and perception of color.
  • One participant seeks to understand how to calculate the new wavelength when combining two laser beams with wavelengths of 0.6328 micrometers and 0.5145 micrometers, questioning if averaging the wavelengths is appropriate.
  • Another participant asserts that photons do not interact in a way that allows their frequencies to add or subtract, suggesting that the frequencies remain independent when combined.
  • A different participant introduces the concept of using an optical diffraction grating, noting that when two laser beams of different colors are directed through it, they appear as a new beam with a new color, prompting a question about how to calculate this new wavelength.
  • One participant compares the combination of wavelengths to mixing colors, explaining that while the perception of color may change, the wavelengths themselves remain distinct and can be separated again.
  • A participant expresses confusion about the possibility of creating a new wavelength from existing wavelengths and seeks clarification on how to add wavelengths together.
Participants express differing views on the nature of combining wavelengths, with some asserting that wavelengths remain independent while others explore the effects of diffraction and perception. The discussion does not reach a consensus on how to calculate a new wavelength from the two given wavelengths.
There are unresolved assumptions regarding the interaction of laser beams and the conditions under which new wavelengths might be perceived or calculated. The discussion lacks clarity on the mathematical steps needed to derive a new wavelength from the existing ones.
engalaanabil
hello , everybody, i need help please
i want to combining two laser beam (coherent lazer) ,
but i don,t know how to calculate the new one
i have the value of the two wavelengths (.6328 micro ) and (.5145 micro ) but how to get the new one ?
can i take the average of them ?
Science news on Phys.org
Photons do not interact that way. Your scenario would simply provide for their own independent frequencies; thus nothing would change.
In other words, photon frequencies do not add or subtract when they mingle.
yes , you are right , but when we insert 2 laser beam each with own color to planner optical diffraction grating ,with a certain angle , they appear at the destination port as a new laser beam with a new color (new wavelength) , qustion how to calculate this wavelength?
are you understanding me?
Even so, if you combine two wavelengths they are really just running parallel. Another beam splitter could get you back to both beams again. Imagine if you had an amount of green light combined with a unit of red light. Just like a color wheel, when they are added they make yellow. Your eye does not receive a yellow color. It receives an equal number of red and green thus perceiving yellow. I hope I explained this right.EDIT - I think I didn't read your last post clearly and I don't know what you asking for. But the slit experiment should break up the two wavelengths at certain intervals.
http://en.wikipedia.org/wiki/Double-slit_experiment
you mean that is we can't make wavelength from other wavelengths,so how to add wavelengths
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 19 ·
  • · Replies 0 ·
