Calculating Potential Energy of a Spring with a Hanging Mass
The discussion revolves around calculating the potential energy of a spring when a mass is hung from it. The problem involves determining the spring constant and the displacement caused by the mass.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of the spring constant using the force and displacement. There are questions about the correctness of the calculated spring constant and the method used to derive it.
Some participants have provided alternative methods for finding displacement and potential energy, while others are verifying calculations and discussing the implications of different values for the spring constant. There is an ongoing exploration of the relationships between the forces, displacements, and potential energy.
Participants mention constraints related to homework assignments and the unavailability of the teacher for immediate assistance. There is a focus on ensuring the calculations align with the physical principles involved.
emeraldempres
A force of 790 N stretches a certain spring a distance of 0.135 m. What is the potential energy of the spring when a mass of 62.0 hangs vertically from it?
I thought starting with finding the spring constant k would be good and i got it to be 585.85. i then plugged it into the potential energy equation u= .5(k)(x)^2 where x is the displacement. I got the new displacement by setting up a porportional equation and the new x was .104 m.
All the answers look correct except for k.
when i calculated k this is what i did
Spring Force(790 N) = (k)(distance(.135m))
and isolated the variable.
what did i do wrong?
What is 790/.135? Your answer for k, just by estimating in my head, is off.
790 is the force in Newtons and i divided it by .135 which is the distance the weight on the spring made the spring stretch, the answer was 5851.85
Ok. You wrote
585.85
Everything else is fine.
Another way to find the displacement would be to set up Newton's second law as well.
[tex]mg+(-k\Delta y=0) \Rightarrow \Deltay=\frac{mg}{k}[/tex]
since you've already know k.
Then plug back into the potential energy of the spring. [tex]U_{s}=\frac{1}{2}ky^2[/tex]
does that help me with finf=ding the potnetial energy?
sorry,i meant does that help me with finding the potential energy?
Yes. The potential energy of a spring is just a formula unless you want to find the total change in potential energy = gravitational potential energy + potential energy of the spring.
using the mg/k equation gave me 1.03 m as my displacement but that does not sound right if the force 0f 709 only gave a displacement of .135 m
Actually you would get ~.1038 =~ .104m which is the distance you're trying to find.
You've already found k, you need to find the distance y(the distance that the object stretches the spring, hence why I used Newton's 2nd law). There are two distances in this problem., one is already given, the other(the distance that the mass is stretching the string so that you can find the potential energy of the spring)is the one you're trying to find.
thank you so much for your help. i am doing my home work online and my summer school teaher gave us a homework assignment due each night of the weekend but is unavailable himself to answer questions. i got the answer though 31.5 J
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 17 ·
