How does the air polarise the light?
  • Context: Undergrad
  • Thread starter Thread starter sharp910sh
    Air Light
The discussion centers on how air polarizes light through scattering mechanisms, specifically Rayleigh and Mie scattering. When light interacts with air molecules, it emits photons at right angles to the light beam, resulting in vertical or horizontal polarization depending on the scattering direction. The highest polarization occurs at 90 degrees to the sun's location, which can be observed through polarized materials like sunstone. Additionally, noctilucent clouds can preferentially polarize sunlight, and historical navigation techniques using Iolite crystals are mentioned.
  • Understanding of Rayleigh and Mie scattering
  • Knowledge of light polarization and its properties
  • Familiarity with polarized materials, such as sunstone
  • Basic concepts of light interaction with atmospheric particles
  • Research the principles of Rayleigh scattering in detail
  • Explore Mie scattering and its effects on light polarization
  • Study the use of polarized materials in navigation
  • Investigate the phenomenon of Haidinger's brushes and its visual implications
Physicists, atmospheric scientists, photographers interested in light behavior, and anyone studying optical phenomena in the atmosphere.
sharp910sh
I'm not sure if this is right but, when the light is absorbed by an air molecule, the air moleclue emits light (photons) in the at right angles to the direction of the light beam therefore in the direction of the electric field. This will cause the light to be either vertically or hoziontally polarised, dependent on the direction of the scatter? correct?
Therefore if you look through the a polarised material ie sunstone, you can find the direction of the sun yes?
I got a picture from a site
Science news on Phys.org
Rayleigh scattering describes how light is scattered by the atmosphere, and Mie scattering is used to include scattering by particulate matter. Both indicate that polarization effects occur, based on the differences between the reflection coefficients of s- and p- polarization incident on a surface. Some clouds (noctilucent) will preferentially polarize sunlight via scattering.
As you look into the sky, the light entering your eyes will have a small amount of polarization, and the region of highest polarization is in quadrature ('90 degrees') to the location of the sun. The effect is very slight and easily obscured by particulate matter in the sky. Some people can see "Haidinger's brushes", and it is rumored that the Vikings used crystals of Iolite to navigate via polarization.
