Thermal conductivity - doped silicon
The discussion revolves around the thermal conductivity of silicon substrates doped with boron, focusing on whether it can be calculated or must be measured, particularly at room temperature with specified dopant concentrations.
  • Technical explanation, Debate/contested, Experimental/applied
  • One participant seeks methods to calculate or measure the thermal conductivity of boron-doped silicon, indicating a need for guidance.
  • Another participant notes that the thermal conductivity of single crystal silicon is weakly dependent on doping, suggesting that the variation due to boron doping is likely less than measurement error.
  • A participant specifies two boron concentrations (8e18 cm-3 and 1.2e15 cm-3) and requests an estimation of thermal conductivity at room temperature.
  • One reply references a source that claims the thermal conductivity at 22°C is approximately 147 W/m-K, asserting that the impact of boron doping is negligible and aligns with the understanding that electronic thermal conductivity is minor compared to lattice thermal conductivity in this context.
Participants express varying views on the dependence of thermal conductivity on boron doping, with some suggesting it is negligible while others seek more precise estimates. The discussion remains unresolved regarding the exact impact of doping on thermal conductivity.
Participants have not reached a consensus on the methods for calculating or measuring thermal conductivity, and there are limitations regarding the assumptions made about doping effects and temperature conditions.
lycoss
I 'trying to find the thermal conductivity of a silicon substrate doped with boron with known dopant concentration. Is there any way to calculate it or it has to be measured.
Thanks in advance for any advice.
You may already know this, but the thermal conductivity of single crystal silicon at normal temperatures is only weakly dependent on doping. The dependence is probably less than the measurement error (I typically see values ranging from 149-157 W/m-K). How precise an answer do you need?
I want to know the conductivity of doped silicon with boron at room temperature. An estimation would be wright too. I have to different concentrations of boron, one of 8e18 (cm-3) and one of 1,2e15 (cm-3).
Thanks in advance
According to the calculations http://www.patentstorm.us/patents/7202146/description.html" (which you may or may not believe), the thermal conductivity at 22°C is 147 W/m-K, and the variation due to boron doping is negligible (<1 W/m-K). This agrees with the idea that electronic thermal conductivity is small compared to lattice thermal conductivity in single crystal silicon around room temperature.
  • · Replies 0 ·
