| Thread Closed |
Grounding in lab. |
Share Thread |
| Jun19-08, 12:48 PM | #1 |
Grounding in lab.
Hi all. We're moving to a new lab and I need to have a reliable ground for ESD protection, e.g. connecting the ESD mat safely. My questions are: can I just use the ground in the power outlet, or I need to request a different ground? Do I need to connect a resistor between the mat and the ground?
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| Jun19-08, 12:55 PM | #2 |
Mentor
The ground in an AC Mains socket should serve the purpose, once you've located the current limiting resistor. |
| Jun19-08, 01:02 PM | #3 |
Recognitions:
You can buy special plugs that only have an earth pin, contain a built in resistor and have the press-stud connector for a ground mat.
It's not especially important that the mat is grounded, just that your, wrist strap+bench mat+floor pad are connected together. If you have an insulation tester or even an ohm meter it's worth checking the grounds of sockets in newly built labs are correctly earthed - it's amazing how many aren't, or have live/neutral swapped etc. |
| Jun19-08, 02:32 PM | #4 |
Grounding in lab.
Well, to check the ground of the socket with an ohm meter, one probe to the "ground", how about another?
| Jun19-08, 03:00 PM | #5 |
Recognitions:
Water pipe, ground outlet in another socket or if you are on the ground floor in a flower bed outside.
| Jun19-08, 03:06 PM | #6 |
Got it! Thank you.
| Jun19-08, 08:33 PM | #7 |
The make a special plug for testing outlets.
Should be < $10 at almost any hardware store. Validates power, ground, reversed wiring, and open connections. |
| Thread Closed |
Similar discussions for: Grounding in lab.
| Do ‘grounding’ and ‘earthing’ mean the same? | Electrical Engineering | 4 | ||
| EMC and Electronic grounding | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Grounding resistance | Introductory Physics Homework | 3 | ||
| grounding question | General Physics | 0 | ||
