What Is the Speed of a Bucket in Vertical Circular Motion?
  • Thread starter Thread starter 0338jw
    Speed
The problem involves a bucket of mass 2.00 kg being whirled in a vertical circle with a radius of 1.10 m. The tension in the rope at the lowest point is given as 25.0 N, and the questions focus on finding the speed of the bucket at both the lowest point and the top of the circle to prevent the rope from going slack.
  • Mixed
  • Participants discuss the net force acting on the bucket and its relation to centripetal acceleration. There are attempts to clarify the correct equations to use for calculating speed and centripetal acceleration at different points in the circular motion.
Some participants have provided guidance on the relationships between forces and acceleration, while others express uncertainty about their calculations and the application of equations. Multiple interpretations of the problem are being explored, particularly regarding the changes in speed and acceleration at different points in the motion.
Participants mention constraints such as the pace of their summer classes and the complexity of the material being covered, which may be contributing to their confusion.
0338jw
A bucket of mass 2.00kg is whirled in a vertical circle of radius 1.10 m. At the lowest point of its motion the tension in the rope supporting the bucket is 25.0 N. a) Find the speed of the bucket. b) How fast must the bucket move at the top of the circle so that the rope does not go slack?
[tex]\Sigma[/tex]Fy= Ft - Fg =m*[tex]a_{c}[/tex]
Ac=v^2/r
I have solved for the net force in the Y direction and I get 5.4N. Is this the net centripetal force that i can use to plug back into F=m *ac for the centripetal acceleration? I get 2.7m/s when i do this. I know this question has been posted before, and I'm sorry but I don't quite get it after reading and rereading bits and pieces of information by others posted in the forum. all help is greatly appreciated!
or when solving for speed do I plug the net force back into F=m(v^2/r)? When I do this and solve for the speed I get 1.72m/s. I'm not sure what I'm doing wrong and which is the correct equation to use.
Yes.
That's the same thing, so I don't see how you got two different answers. Show exactly what you did.
I see what you did here: You solved for the centripetal acceleration. (That should be 2.7 m/s^2--not m/s.) You need to solve for the speed, which you did in your second post.
Ohh okay! So now I have the acceleration as 2.7 m/s/s and the speed as 1.72 m/s. Does the centripetal acceleration remain the same for when the bucket is at the top of the circle? I know the force of tension is 0 and that the bucket must be swinging fast enough to overcome the weight of the bucket and water to keep it from falling down. I'm not sure how to write this in equations though. the sum of the forces in the Y direction is FT + Fg =m*ac? Again, sorry if I'm not seeing something obvious I'm taking a couple summer classes and we're flying through some important stuff pretty quickly.
No.
Right! You solve it exactly like you solved the first part.
Wait, centripetal acceleration is v^2/r. At the top of the circle neither v nor r change. Its circular motion.
The speed changes. (Don't confuse this with uniform circular motion, where the speed stays constant.)
thank you for the help! When I solved for velocity I got 3.28 m/s. It should be right, but I'm still not very confident in my work yet. Again, thanks for the help!
Sounds good to me!
