Power wind calculation and blade area
The discussion revolves around the theoretical power that can be extracted from wind using wind turbines, focusing on the influence of blade area on output power. Participants explore the relationship between wind power density (WPD), blade design, and the assumptions underlying the calculations of power extraction from wind.
  • Grinch presents a formula for calculating power from wind, questioning the role of blade area in this calculation and whether it affects the total power output.
  • Some participants propose that the total power collected is significantly dependent on blade area and blade design, suggesting a need for detailed analysis of blade shape.
  • Grinch acknowledges that the theoretical maximum power calculated does not account for practical limitations, such as the inability to capture all energy from the air parcel due to blade rotation and air flow dynamics.
  • Another participant mentions that maximum power represents the kinetic energy in the wind and suggests looking at performance curves from various wind turbine websites to understand efficiencies related to different blade configurations.
Participants express differing views on the importance of blade area in power calculations, with some asserting its significance while others emphasize theoretical limits and practical inefficiencies. The discussion remains unresolved regarding the exact role of blade area in determining output power.
Participants highlight that the WPD is a theoretical maximum and that real-world factors, such as blade design and air parcel dynamics, complicate the extraction of power from wind. There is also mention of Betz's Law as a limiting factor in power extraction.
Grinch
Dear all,
I'm just doing some thinking around the maximum theoretical power that can be extracted from wind by using a wind plant.
Derivation of the power inside a block of wind is not difficult then I'll simply report some consideration regarding this subject (look at the attached paper for details).
At first we've to assume some air density, speed, and area of the air parcel that is going to the plant, put all together will give (look at the Pwr relation on the page 2 of attached PDF):
Pwr = 1/2 * (rho * V^3 * A)
As defined A stand for the area of the air parcel.
Now I've a question about the role of the blade area into the output power that I can generate from the plant. Looking at the formulae seems that the blade area have no influence because the area A are simply calculated as pi*R^2 where R is the blade length.
Of course there is some consideration about the blade speed, if too slow only a little part of the air will be collected, if too high turbolence may also decrease the output power and then there is a compromise from the air speed and the blade speed but the concept is there is a way to show a dipendence from the blade area and the total air parcel cross section area or really this is not important and the final resul will be independent from the geometrical blade area?
In other word, if I suppose a blade area equal to S and n°3 blade my total useful area will be equal to 3S then, if we've a unity ideal conversion ratio the energy that I can collect from the air parcel should be proportional to 3S then also the final power sould be proportional to the 3S area... or not... (take also care that my question is different than the Bets law http://en.wikipedia.org/wiki/Betz'_law, is just a matter to know if really the blade area isn't important or have some role into the final energy and then power computation).
Thanks in advance
Grinch
I'm sorry to boring again, could someone take a look at my question?
Tnx
Grinch
I looked at your question and I think that the analysis of the WPD you have presented is reasonable.
The total power collected will very much depend on the blade area and the design of the blades. To calculate this dependence you would need to analyze the Bernoulli force that spins the blades:
http://hyperphysics.phy-astr.gsu.edu/Hbase/pber.html
The problem is that the WPD is just a theoretical maximum. To determine the output in a specific case we would need need to analyze the shape of the blades in a detailed way.
Dear Crosson,
first we like to thank you for your time, after that your phrase give me some comfort:
I'm totally agree with you, the power extracted from the wind is just a theoretical calculation, in other word I'll expect to extract a maximum power equal to the calculated one if I'm able to collect every energy from the air parcel, but a simple things show that is not possible for many reason, most simply when blade are rotating a time t only a part of the air parcel will be intercepted and then some energy is lost, at t+dt blade rotate but some other part of the air parcel has gone away trought the area not covered by the blade and so on... focusing on this simple reasoning I've figured out that this formula isn't really applicabile and give us a maximum theoretical value that can't be absolutely reached. Other than there is also a consideration concerning the Betz Law that set another limit to the maximum power achievable from wind.
Then from this point of view the maximum power value should be considered as a indicator of the maximum final value of the power that I'll can extract from wind...
Well Crosson, again I like to say thank you for your time.
If you have some other ideas or calculation or some other infos please feel free to let me know.
Regards
Grinch
Maximum power is just the kinetic energy in the wind. There are numerious wind turbine websites that have performance curves for various wind machines. You can deduce system efficiencies from these curves. You can Compare different efficiencies with different blade diamenters, configurations etc.
  • · Replies 69 ·
18K
  • · Replies 169 ·
17K
