The discussion revolves around the thermal expansivity of hardwood, specifically in the context of measuring the length of an air column using a hardwood ruler in a temperature range from 0 to 100 degrees Celsius. Participants explore how to calculate the percentage error introduced by the ruler's thermal expansion and seek information on the coefficient of thermal expansion for hardwood.
- Exploratory
- Technical explanation
- Debate/contested
- Homework-related
- One participant asks how to find the percentage error of a hardwood ruler compared to actual graduations, seeking the thermal expansivity coefficient of hardwood.
- Another participant suggests searching for Young's Modulus, but later corrects themselves to recommend looking for the coefficient of expansion instead.
- Some participants express frustration over the use of informal language and abbreviations in the initial question, emphasizing the importance of clear communication.
- A participant mentions the need for a good varnish on the wooden ruler to prevent swelling from water exposure, suggesting that a metal ruler might be a better choice for measuring thermal expansion.
- One participant proposes measuring the expansion of two rulers at different temperatures to obtain a more accurate estimate of thermal expansion.
- Another participant provides the equation for linear expansion, indicating how to calculate the change in length due to temperature change.
- There is mention of the CRC Handbook of Chemistry and Physics as a resource for finding the thermal expansivity of hardwood, with varying opinions on the reliability of different editions.
- Concerns are raised about the contribution of moisture to the thermal expansion of wood, suggesting that this factor complicates the use of standard expansivity data.
Participants express a mix of agreement and disagreement, particularly regarding the appropriateness of using a hardwood ruler in the experiment and the clarity of communication. There is no consensus on the best approach to measure thermal expansion or the reliability of available resources.
Limitations include the potential impact of moisture on the thermal expansion of wood, the variability in properties of different types of hardwood, and the uncertainty in the measurements due to the ruler's own inaccuracies.
This discussion may be useful for students and researchers interested in experimental physics, particularly those exploring thermal expansion and measurement techniques in laboratory settings.
