What Is the Normalization Constant and Lowest Energy of an Electron in a 1D Box?
  • Thread starter Thread starter Domnu
    Box Electron
The normalization constant for an electron in a one-dimensional box with walls at x=(0,a) is determined to be A = √(1/a). The lowest energy of the electron in this quantum state is non-zero due to confinement, as dictated by the Heisenberg uncertainty principle. The wavefunction provided, which is a step function, does not correspond to the typical sine functions of energy eigenstates, necessitating a Fourier series representation to express measurable energies. This highlights the unique characteristics of the quantum state in question.
  • Quantum mechanics fundamentals
  • Understanding of wavefunctions and normalization
  • Familiarity with the Heisenberg uncertainty principle
  • Knowledge of Fourier series and energy eigenfunctions
  • Study the derivation of wavefunctions for a particle in a one-dimensional infinite potential well
  • Learn about the implications of the Heisenberg uncertainty principle in quantum mechanics
  • Explore Fourier series and their application in quantum state analysis
  • Investigate the properties of delta functions and their role in quantum mechanics
Students and professionals in physics, particularly those focusing on quantum mechanics, wavefunction analysis, and energy quantization in confined systems.
Domnu
Problem
An electron in a one-dimensional box with walls at [tex]x=(0,a)[/tex] is in the quantum state
[tex]\psi(x) = A, 0<x<a/2[/tex]
[tex]\psi(x) = -A, a/2 < x < a[/tex]
Obtain an expression for the normalization constant, [tex]A[/tex]. What is the lowest energy of the electron that will be measured in this state?
Solution
Well, we know that
[tex]\int_{0}^A |\psi(x)|^2 dx = 1 \iff A^2 \cdot a = 1 \iff A = \sqrt{\frac{1}{a}}[/tex]
so this is our normalization constant, [tex]A[/tex]. Now, to find the lowest energy of the electrong that will be measured in this state, we have:
[tex]-\frac{\hbar^2}{2m} \frac{\partial^2 \psi}{\partial x^2} = E \psi[/tex]
but the left hand side evaluates to 0 since [tex]\psi[/tex] is independent of [tex]x[/tex]. So this is the lowest (and only observed) energy in this state... is this right?
Well, [tex]\psi[/tex] is independent of [tex]x[/tex] everywhere except around [tex]x = a / 2[/tex]. Around there things could get a little weird. (In fact, as this problem is stated, [tex]\psi[/tex] changes infinitely quickly from one side of [tex]a / 2[/tex] to the other, so around there things could get very weird.)
Even without doing any calculations, though, you should know that since the electron is stuck in the box, it must have nonzero energy. If nothing else, the box gives it [tex]\Delta x < \infty[/tex], so it must have [tex]\Delta p > 0[/tex] by Heisenberg.
If you've already studied the infinite potential well (one-dimensional box), you might also know that the energy eigenfunctions (or stationary states) are all [tex]sin[/tex] functions (since one of the walls is at [tex]x = 0[/tex]). Now, the given wavefunction [tex]\psi[/tex] is not such a [tex]sin[/tex] function, so to get the measurable energies we have to rewrite it as a sum of the energy eigenfunctions -- that is, as a Fourier series of [tex]sin[/tex] functions.
Hopefully that's enough to get you started.
Well, its a step function so if you compute the derivative you get a delta function...and then a derivative of a delta function and so on.
By the way, if you solve for the wavefunction of a particle in a 1D box, you get sin or cosine functions. Any state the particle is in can be written as a linear combination of these eigenfunctions. This is a rather strange state...and interesting too :smile:
  • · Replies 24 ·
  • · Replies 20 ·
  • · Replies 30 ·
