Wind Turbine Dynamics: Unraveling the Mystery
The discussion revolves around the dynamics of wind turbines, particularly focusing on the angle of attack of the blades and the aerodynamic principles involved. Participants explore the relationship between blade orientation, wind speed, and lift generation, while considering different models and analogies, such as comparing turbine blades to airplane wings and sailboats.
  • One participant expresses confusion about the angle of attack of a wind turbine's blades, suggesting that a ~70 degree angle of attack seems beyond the stall angle, questioning the model of lift generation.
  • Another participant proposes that the turbine may not function like a classical turbine and suggests it could resemble a Pelton wheel, which relies on frontal area rather than aerodynamic lift.
  • A participant references a source discussing how the rotation of the blades can delay stall due to centrifugal effects and favorable pressure gradients, indicating a complex interaction between blade motion and airflow.
  • Further elaboration is provided on how the relative wind speed and the motion of the blades affect the actual angle of attack, suggesting that the angle of attack is not solely determined by the blade's orientation to the wind.
  • Participants discuss the differences in controlling angle of attack in airplanes versus wind turbines and sailboats, emphasizing the constraints imposed by wind direction and motion.
  • There is a technical discussion about calculating tip speed, relative wind, and actual angle of attack based on blade rotation and wind conditions, indicating a mathematical approach to understanding turbine dynamics.
Participants express differing views on the mechanics of wind turbine operation, particularly regarding the angle of attack and the role of aerodynamic lift versus frontal area. The discussion remains unresolved, with multiple competing perspectives on how these factors interact.
Some assumptions about the operation of wind turbines and the definitions of aerodynamic terms are not fully clarified, leading to potential misunderstandings. The discussion includes references to external sources that may not be universally accepted or agreed upon by all participants.
DaveC426913
2025 Award
Nope. I'm still having trouble. I asked about this before, but it's still not gelling for me.
There's a wind turbine on the "front lawn" of the city of Toronto that I pass every day. Its blades are never more than ~20 degrees from flat, i.e the blades are almost perpendicular to the flow of air. If my model of lift generated by the blades is correct*, that represents a ~70 degree angle of attack. Surely that's beyond stall angle.
What am I missing? Perhaps there's something about 'relative' angle of attack based on slow wind speed and fast blade movement?
* my understanding of wind turbine blades is that you can liken it to a plane, with the turbine shaft as the fuselage and each blade as a wing. The lift generated by each blade is perpendicular to the shaft and is parallel to the plane of the rotor i.e. the lift acts to increase the rotation of the rotor.
There is a very good chance that it is not really a turbine in the classical sense. It could be similar to a Pelton wheel which is a reaction turbine. With such a steep AoA, this makes a bit more sense that they are not relying on aerodynamics of lift but rather just trying to get as much frontal area perpendicular to the wind.
Nope. It's http://upload.wikimedia.org/wikipedia/commons/thumb/f/f4/Windshare-toronto_hydro-wind_turbine-20030223.jpg/450px-Windshare-toronto_hydro-wind_turbine-20030223.jpg" .
I found this:
"The rotation of the blades delays the static stall, because the centrifugal pumping results in Coriolis acceleration terms that induce favourable pressure gradients. The result is that boundary layer separation is delayed. "
http://aerodyn.org/Rotors/wturbine.html
...which is sort of what I was alluding to in the OP - even though I didn't know what I was tlaking about.
Ahh. I see. OK. Next theory.
If the blades are spinning, their motion contributes to the wind speed and the resulting relative wind is the actual angle of attack, not the angle of the blades wrt the wind.
http://www.physclips.unsw.edu.au/jw/sailing.html
Both a sailboat and a wind turbine, when starting from a dead stop will have a normal looking angle of attack that then increases as it accelerates. Ie, the blades will point toward the wind and as it accelerates, they will rotate to flatten-out. This is actually computer controlled and constantly being adjusted.
If you count the rpms and estimate the diameter and pitch angle at the tip and wind speed, you can calulate the tip speed, relative wind, and actual angle of attack.
Yes, the resultant vector is always perpendicular to the chord of the airfoil. But the resultant vector isn't the lift vector, it is a combination of the lift and drag vectors. The lift vector is perpendicular to the relative wind direction.
But, while in an airplane you can change your aoa to make sure your lift vector points in the direction you want it to, in a sailboat and in a wind turbine, you are limited by your dependence on the wind (in an airplane, you make the wind go in the direction you want it to). So sometimes you have to accept a lift vector that isn't parallel to your direction of motion. Again, in the sailing website from above, you can see that when the boat is moving upwind, the force vector pushing the boat forward is tiny compared to the force vector pushing it sideways. But the centerboard of the boat (and the shaft of the windmill) constrains the motion to the direction you want.
Yeah, I'm a sailor. So I get the apparent wind thing.
Right, so, if some section of the blade is slicing the air at, say 50ft/s, and its angle were 20 degrees, then I can conclude that the wind at that point is moving past at 50*sin(20)?
43K
