How Can Infinitely Many Integers Make n² + (n+1)² a Perfect Square?
  • Context: Undergrad
  • Thread starter Thread starter qaz
The discussion revolves around the problem of demonstrating that there are infinitely many integers \( n \) such that \( n^2 + (n+1)^2 \) is a perfect square. Participants explore the connection to Pell's equation and various mathematical manipulations to approach the problem.
  • One participant expresses difficulty in applying Pell's equation to the problem and seeks guidance.
  • Another participant notes the existence of two forms of Pell's equation and suggests that there may be infinitely many solutions when \( n \) is not a perfect square.
  • A participant derives the equation \( n^2 + (n+1)^2 = m^2 \) and manipulates it to arrive at a quadratic equation in \( n \), indicating that \( n \) will be an integer if the expression inside the square root is a perfect square.
  • This participant identifies the condition \( 2m^2 - 1 = k^2 \) as a Pell's equation, asserting that since \( D = 2 \) is not a square number, there are infinitely many integer solutions for \( (m, k) \) and consequently for \( n \).
  • Another participant introduces concepts from Pythagorean triples and relates them to Pell's equations, suggesting that there are infinite solutions to the original problem based on these relationships.
Participants generally agree on the connection between the problem and Pell's equation, but there are varying interpretations and approaches to the problem. The discussion remains unresolved regarding the specific applications and implications of these mathematical relationships.
Some assumptions about the forms of Pell's equation and the conditions under which solutions exist are not fully explored. The dependence on the nature of \( n \) and the implications of different forms of Pell's equation are also noted but not resolved.
qaz
i am having some trouble with this problem.
show that there are infinitely many integers n so that n^2+(n+1)^2 is a perfect square. (reduce to pell's equation).
i know pell's equation but don't know how to apply it with this problem.
pell's equation: n*x^2 + 1 = y^2.
-thanks.
I've seen Pell's equation also written as [itex]nx^2 - 1 = y^2[/itex], so maybe there are two forms, one with a plus sign, one with a minus sign. One fact about Pell's equation is that there are an infinite number of positive integer pair solutions (x,y) when n is not a perfect square integer (hopefully this holds for the case where there's a minus sign, otherwise my hint will be useless!).
Anyway, here's the hint: see what condition(s) you can extract when you try to solve the equation that results when you write [itex]n^2 + (n+1)^2[/itex] as a perfect square (i.e. when you solve the following equation for n: [itex]n^2 + (n+1)^2 = m^2[/itex])
hmmm, ok, but i still don't see how you can apply that to get further.
Alright. So we want to solve the following equation for n:
n^2 + (n+1)^2 = m^2
where m is an integer. After a bit of manipulation we arrive at:
2n^2 + 2n + (1 + m^2) = 0
The solutions of this equation are:
n = (-2 +/- sqrt(4 - 8(1 + m^2))/4)
Or:
n = 1/2 (-1 +/- sqrt(2m^2 - 1))
Now the only way that n is going to be an integer is if the expression inside the square root sign is a square number. Or in other words:
2m^2 - 1 = k^2
where k is an integer. This is the same as Pell's equation (with the minus sign), i.e.:
Dx^2 - 1 = y^2
Now we know that Pell's equation has infinitely many integer pair solutions (x,y) if D is not a square number. In our case, D is 2, which is not a square number. So there are an infinite number of integer pair solutions (m,k). And so there are an infinite number of integers n which are solutions to our first equation. And so there are infinitely many integers n such that n^2 + (n+1)^2 is a perfect square.
In the Pell equation for a prime of the form p=4k+1 or 2, we have:
Y^2 -pX^2 = +/- 1.
Now for the Pathagorean triples, we have X^2 + Y^2 = Z^2, where it can be shown that absolute value of X=b^2-a^2, Absolute value of Y = 2ab, Z = a^2 + b^2, for a, b integers.
Thus we have a form like N=b^2-a^2, N+1 = 2ab.
Subtracting we get 1 = a^2 +2ab - b^2 = (a+b)^2 - 2b^2. This is a Pellian equation. Here we could also have the equation (b-a)^2 -2a^2 =-1, if N+1 had been chosen as absolute value of b^2-a^2.
Take the case of 3^2 -2x2^2 = 1. In this case we have a+b =3, b =2, a=1,
This gives: 3^2 +4^2 = 5^2. Now in the case, 7^2 -2x5^2 = -1. Here in the second case where n+1 = absolute value of b^2-a^2, we have b=2, -a=5. This gives the form 20^2 + 21^2 = 29^2.
Since there is an infinite number of solutions to X^2-2Y^2 = +/- 1, we have an infinite number of solutions to n^2 + (n+1)^2 = u^2 in integers.
  • · Replies 25 ·
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 17 ·
