Common mode noise and balanced detectors
The discussion focuses on the functionality of balanced photodetectors in laser interferometry systems, specifically their ability to reject common-mode noise. Common-mode noise refers to interference that affects both detectors equally, which is effectively filtered out through the subtraction process inherent in balanced detection. This mechanism allows the desired signal to be preserved while eliminating noise that is common to both inputs. The participants reference the Common-Mode Rejection Ratio (CMRR) and Optical Hybrids as key concepts in understanding this technology.
  • Understanding of laser interferometry systems
  • Familiarity with balanced photodetector technology
  • Knowledge of Common-Mode Rejection Ratio (CMRR)
  • Basic principles of optical hybrids
  • Research the principles of laser interferometry and its applications
  • Study the design and operation of balanced photodetectors
  • Explore the mathematical formulation of Common-Mode Rejection Ratio (CMRR)
  • Investigate the role of optical hybrids in signal processing
Researchers and engineers in optical engineering, physicists working with laser systems, and anyone involved in signal processing who seeks to understand noise reduction techniques in balanced detection systems.
matheyrichs
I'm working on a laser interferometry system that uses a pair of balanced photodetectors to record the signal. Each detector is on a separate port of a beamsplitter cube, and as a result receives (in theory) the SAME signal. The rationale for using the balanced detectors is that "they reject common-mode noise on the signal".
What exactly is this common-mode noise in the first place? If it is something present at the detector in each signal, then why does that specific piece of the signal get filtered? It seems to me if this is really as simple as subtracting what's common at each detector, then the desired signal would also be lost (seeing that it is the same at each point...).
Can anyone help me understand how a balanced detector scheme works? Thanks!
...if both inputs fluctuate by the same amount (while remaining constant relative to each other), this change will have no bearing on the output.
http://en.wikipedia.org/wiki/Common-mode_rejection_ratio"
You may have seen this wikipedia discription of Optical Hybrids. But I think it will answer your question about balanced detectors.
http://en.wikipedia.org/wiki/Optical_hybrid"
Regards
Don
  • · Replies 152 ·
12K
  • · Replies 0 ·
