Proving the Identity Theorem for Analytic Functions on Open Strips
  • Context: Graduate
  • Thread starter Thread starter arnesmeets
The discussion revolves around proving the identity theorem for analytic functions defined on open strips. Participants explore the implications of the function being analytic and continuous, particularly in relation to its zeros on the real line.
  • One participant asks for help in proving that an analytic function, which is zero on the real line, must be identically zero.
  • Another participant suggests considering standard results related to when an analytic function can be zero.
  • A participant mentions the identity theorem but notes that it cannot be applied directly in this case because the function is not zero inside the region where it is analytic.
  • There is a suggestion to explore extending the function to be analytic in the region where it is zero.
  • Continuity on the closure of the set is highlighted as a crucial aspect that must be utilized in the proof.
  • One participant reflects on previous discussions about analytic continuation and boundaries that may prevent it, questioning if the function's behavior at the boundary is relevant.
  • Another participant clarifies that having zeros accumulating at the boundary is distinct from the function approaching zero at the boundary, providing an example with the function sin(1/z).
  • A participant proposes defining a new function g_y and uses Cauchy's theorem along with continuity to derive that f(iy) equals zero, suggesting that the identity theorem can then be applied.
Participants express differing views on the applicability of the identity theorem and the implications of continuity and boundary behavior. There is no consensus on the resolution of the problem, and multiple perspectives remain on how to approach the proof.
Participants mention limitations related to the conditions under which analytic continuation can occur, the significance of boundaries, and the behavior of functions at those boundaries. These aspects are not resolved within the discussion.
arnesmeets
Let f be analytic on {z : 0 < I am z < 1} and continuous on the closure of this set.
Suppose that f(z) = 0 if z is real. Show that f is identically zero.
Any help please?
Well, what (standard?) results do you know that might help? Any that tell you when an analytic function is zero? I can think of 2, one of which gives you the answer.
Well, I know the identity theorem, but we can't apply it here :(
[because f is not zero inside the region where f is analytic]
Can you think of anyway to extend f to be analytic on the region where it is zero?
Of course the fact that f is continuous on the closure of the set is crucial- you will have to use that.
I once asked about what kind of things can happen that prevent analytic continuation. I think it turned out that there can be boundaries (lines or other one dimensional manifolds) over which analytic continuation cannot be carried out, and was it the reason, that the function approaches zero or infinity at the boundary? If the claim in opening post is correct, I'm probably remembering something wrong then?
Or does the boundary of continuation arise so that the function does not have any limits on it?
My mistake. I was thinking about this: http://en.wikipedia.org/wiki/Domain_of_holomorphy
When n = 1, then every open set is a domain of holomorphy: we can define a holomorphic function which has zeros which accumulate everywhere on the boundary of the domain
But it doesn't give a counter example to the claim in the opening post.
I would hope it doesn't give a counter example: the reflection principle is one of the most elementary results in complex analysis - it's a simple consequence of Morera's theorem.
jostpuur - having zeros which accumulate at the boundary is different from saying that it goes to zero at the boundary.
eg, sin(1/z) is defined for z !=0 and has zeros which accumulate at z=0, but it doesn't go to zero as z->0.
I had understood this by the time of my previous post, where I said that the function described by the Wikipedia isn't a counter example.
When writing post #6, I thought I had seen something that could be a counter example, but then I found the Wikipedia page, took a closer look, and noticed that I remembered it wrong, and then wrote the post #7.
Define [itex]g_y : \mathbb{R} \rightarrow \mathbb{C}[/itex] so that [itex]g_y(x) = f(x+iy)[/itex]. Cauchy's theorem plus continuity of [itex]f[/itex] at the boundary imply that
[tex]\int_{-a}^a (g_y(x)+g_y(-x))dx = 0[/tex]
(taking a symmetric rectangular contour with base arbitrarily close to the real line). The continuity of [itex]g_y[/itex] gives that
[tex]\frac{1}{2\epsilon} \int_{\epsilon}^{\epsilon} (g_y(x)+g_y(-x))dx \Rightarrow g_y(0)[/tex]
So [itex]f(iy)=0[/itex], and you can apply the identity theorem.
