Can Holding a Teacup Make Tea Cool Faster?
  • Context: High School
  • Thread starter Thread starter Harut82
    Cooling
The discussion revolves around whether holding a teacup with both hands affects the cooling rate of the tea inside compared to letting the cup sit. Participants explore the implications of heat transfer between the tea, the cup, the hands, and the surrounding air, considering various factors such as temperature differences and material properties.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant suggests that holding the cup will help it cool faster due to heat transfer from the tea to the hands, arguing that the temperature of the hand is greater than that of the surrounding air.
  • Another participant notes that the outcome depends on the temperatures of the air and the hand, indicating that specific conditions matter.
  • Several participants propose conducting an experiment with a thermometer to determine the cooling rates empirically.
  • One participant introduces a differential equation model to analyze the cooling process, suggesting that the constant in the equation could be affected by the presence of hands, potentially leading to a faster cooling rate.
  • Another participant agrees that the solid nature of the hand allows for more efficient heat transfer compared to air, which may justify an increase in the cooling constant in the differential equation.
  • There is a discussion about the final temperature achieved when holding the cup, with one participant arguing that while the cooling may be faster initially, the final temperature could be higher, complicating the definition of "speed" in this context.
  • One participant highlights the non-linear nature of heat transfer due to the body's internal heating/cooling system, suggesting that this adds complexity to the analysis.
Participants express differing views on the effects of holding the cup on cooling rates, with some supporting the idea that it cools faster and others raising conditions that could lead to different outcomes. The discussion remains unresolved with multiple competing perspectives.
Participants mention various assumptions regarding temperatures and constants in their models, indicating that the conclusions drawn may depend heavily on these parameters. There is also a recognition that the cooling process is influenced by multiple factors, including the specific conditions of the experiment.
Which cup will cool faster
  • Total voters
Harut82
We were having tea with the family and my brother and I started wondering if holding the cup will help in cooling the tea.
Lets say you have two identical cups filled with the same amount of the same temperature tea.
You let one just sit and the other you grab with both hands . . . which tea will cool quicker?
When you hold a hot teacup you feel heat transfering to your hand. I argued that holding the cup with both hands will help it cool faster.
Temperature of hand > temperature of surrounding air near cup
therefore tea cools faster
am I wrong?
Science news on Phys.org
Depends on the temperature of the air and of your hand.
One way to know for sure. Find a thermometer and do the experiment.
Air is room temperature. Let's say 72 degrees.
Body temperature 98.6 degrees.
I'd suspect that the constant in the differential equation, caused by your hands, would lower the temperature faster. If you look at the differential equation,
[tex]T'=k(T_e-T)[/tex]
it would seem that a mere doubling in the constant (which is not unreasonable in going from air to your hands) would have a much more profound affect on the time derivative of temperature than the lower temperature of the air, assuming [itex]T_o>130[/itex]. Just a thought, test it to see for sure.
Would I be right in saying a solid like your hand would be much more capable of transporting heat than air due to its higher density. Is this why you would increase the constant in the differential?
Of course the cup wouldn't attain the same equilibrium temperature as your hadns are warmer than the air. Also the transfer of heat to air from your hands would have to be taken into account and its conduction through your arms. I suspect if you have a very big cup of tea that you are not able to grasp properly then it wouldn't make much difference :)
But for a normal cup I would say it would cool faster with both hands.
Alex
Yea, that was my reasoning and it holds for any cup. Substituting a small portion of a huge cup with your hands would still help lower the temperature more quickly. We can be more quantitative, T1 is the temp of the cup without the hands, T2 is with the hands. The solution the the differential equations are:
[tex]T_1=T_c+(T_o-T_c)e^{-k_ct}[/tex]
where:
-[itex]T_c[/itex] is the temp of the cup
-[itex]T_o[/itex] is the initial temp of the tea
-[itex]k_c[/itex] is the constant between the cup and the tea.
and
[tex]T_2=T_h+(T_o-T_h)e^{-k_ht}[/tex]
where everything is the same as above but the h subscript means hands.
We need to take into account the value of the temperature that you find fitting for the tea, which we call [itex]T_r[/itex]. Set both equations equal to that and solve for t. The results are:
[tex]t_c=\frac{1}{k_c}\log\frac{T_o-T_c}{T_r-T_c}[/tex]
[tex]t_h=\frac{1}{k_h}\log\frac{T_o-T_h}{T_r-T_h}[/tex].
If we substitute some reasonable values in (i use fahrenheit), [itex]T_r=110, T_o=210, T_h=98.6, T_c=72[/itex], and [itex]k_c=1,k_h=2[/itex] (it's not unreasonable for the hand constant to be twice the cup constant, btw 1 and 2 are WAY too high for the constants, but the ratio 1/2 is all that matters) we find,
[tex]t_c\approx1.29[/tex]
and
[tex]t_h\approx1.14[/tex].
So the hands cool it faster in this case.
Trick is, final temperature with cup hold in hands is higher, so in fact final answer depends on the way you define the speed - at higher temps it will be faster but at lower temps it will be slower.
And let's not forget that your hands are not just solid, you also have an internal heating/cooling system so the answer of your body (heat transfer speed) is non-linear.
  • · Replies 152 ·
12K
  • · Replies 39 ·
  • · Replies 186 ·
97K
