What is the Motion of the Center of Mass in a Billiard Ball Collision?
The discussion revolves around the motion of the center of mass during collisions involving billiard balls. The original poster presents a scenario with two identical billiard balls, one moving and the other stationary, and seeks to understand the motion of both the balls and their center of mass before and after the collision.
  • Participants explore the location of the center of mass, questioning whether it remains stationary or changes as the balls move. They discuss the implications of external forces on the center of mass's velocity and consider how the center of mass behaves in different collision scenarios.
Some participants have provided insights regarding the center of mass's position and motion, while others are still clarifying their understanding of the concepts involved. The conversation reflects a mix of correct assertions and ongoing inquiries, indicating a productive exploration of the topic.
Participants are working under the constraints of homework assignments, which may influence their approach to the questions raised. There is also a mention of a deadline for another homework task, adding to the context of urgency in the discussion.
zila24
Consider two identical billiard balls – one with velocity v and the other stationary. They collide with each other. (a) Describe the motion of the two balls after the collision. (b) Describe the motion of the centre of mass of the two balls before the collision. (c) Describe the motion of the centre of mass of the two balls after the collision.
i got the answer to the first part of this question but I am having trouble with b and c.
Okay, where is the centre of mass located?
in the middle of the ball ?
Sorry, I meant where is the combined centre of mass of both balls located?
would it be half way between them?
Correct, the centre of mass of the two balls is at the point half-way between them. So, does this point remain stationary?
no as the first ball gets closer, the center of mass chnages to remain in the middle of both...?
Correct, so how fast does it change, i.e. at what speed does the centre of mass move?
velocity v
zila24 said:
velocity v
Correct :approve:. The same logic can be applied to answer question (c). Alternatively, since there are no external forces acting on the centre of mass of the system, what can you deduce about it's velocity?
since its the other billiard ball that is traveling with a velocity v, now the center of mass is traveling with velocity v
Correct :approve:. You could have also arrived at the same result by reasoning that since there is no net external force acting on the centre of mass, that it will continue with uniform velocity.
thank you...i think i get it... i had another question with a similar problem
Two identical balls, each with velocity v, strike each other at right angles to each other. They stick together. Ignoring friction, (a) describe the motion of the combined ball after the collision and (b) describe the motion of the centre of mass of the two balls before and after the collision
would the motion be in the resultant vector of the 90 angle?
since they are together would it be in between them at the same angle and speed?
hootenanny- is the center of mass not moving at (V/2) m/s?
Your in my physics class aren't you??
Oh my word! I must be half asleep, you are indeed correct Viking! Sorry for the mix up guys, I guess I need some sleep :zzz:.
zila24: To determine the velocity of the centre of mass you need to consider the total momentum of the two balls. This total momentum must be equal to the momentum of the centre of mass. Since you already know the mass of the centre of mass, you should easily be able to determine the velocity, which as Viking correctly says is V/2.
Once again, sorry for the mix-up guys :blushing:.
oh ok... am i right about the second question?
after the collision since they are together where would the CM be and the velocity ?
lol ace123 yeaa i just saw ur post
Did you know homework 8 is due tommorow as well?
yea i just checked my email =/ too much work!
  • · Replies 25 ·
