Constrained optimization troubles
The discussion focuses on finding the largest volume of a regular parallelepiped inscribed in the ellipsoid defined by the equation x²/a² + y²/b² + z²/c² = 1 using the Lagrangian method. The user attempts to minimize the function f = xyz under the constraint provided, leading to a system of equations derived from the Lagrange multiplier method. The resulting equations indicate that if any of x, y, or z equals zero, the volume is minimized to zero, prompting the need to eliminate the Lagrange multiplier λ to find non-zero solutions. The user concludes that substituting y and z in terms of x allows for solving the ellipsoid constraint effectively.
  • Understanding of Lagrangian optimization techniques
  • Familiarity with ellipsoidal geometry and equations
  • Knowledge of solving systems of equations
  • Basic calculus, particularly differentiation and optimization
  • Study advanced applications of the Lagrange multiplier method in optimization problems
  • Explore geometric properties of ellipsoids and their applications in optimization
  • Learn about numerical methods for solving nonlinear equations
  • Investigate alternative optimization techniques such as gradient descent
Mathematicians, optimization specialists, and students studying advanced calculus or applied mathematics who are interested in constrained optimization problems and geometric applications.
Eric Worceste
I'm trying to find the regular parallelepiped with sides parallel to the coordinate axis inscribed in the ellipsoid x[2]/a[2] + y[2]/b[2] + z[2]/c[2] = 1 that has the largest volume. I've been trying the Lagrangian method: minimize f = (x)(y)(z), subject to the constraint (x[2]/a[2] + y[2]/b[2] + z[2]/c[2] - 1 = 0.
My new function F = (x)(y)(z) + L(x[2]/a[2] + y[2]/b[2] + z[2]/c[2] - 1) however leads to zeroes after differentiation and the linear system is solved. I'm stuck . . .
The linear system is solved? What's bad about that? If you mean x= 0, y= 0, z= 0 are solutions, that's a solution but is not the only solution.
What you get, using the LaGrange multiplier method, is:
[itex]yz=2\lambda x/a[/itex]
[itex]xz= 2\lamda y/b[/itex]
[itex]xy= 2\lambda z/c[/itex]
Since anyone of those being 0 will give volume 0, that's obviously the minimum. Assuming none are 0, we can eliminate [itex]\lambda[/itex] by dividing one equation by another. For example, dividing the second equation by the first gives x/y= ay/bx which, in turn gives [itex]y^2= b^2x/a^2[/itex] so (we can assume x and y are positive here) y= bx/a. Similarly, dividing the second equation by the third results in z= cx/a. replace y and z in [itex]x^2/a^2+ y^2/b^2+ z^2/c^2= 1[/itex] and solve for x.
