The Relationship between work, force and distance
by tascja
Tags: distance, force, relationship, work
tascja
tascja is offline
#1
Jul3-08, 12:55 PM
P: 87
I am supposed to relate work, force and distance to each other and to a sport.
2. The attempt at a solution
I chose to describe golf. Here is how I am relating work, force and distance in the game. Could someone just check to make sure I have the right relationships?
1. When the golfers club hits the ball the kinetic energy from his swing gets transfered to his golf ball
2. Because of his energy he is able to do work - applying a force and making the ball move a certain distance
3. the more energy he gives to his swing the more work he can do. Therefore a greater force will be applied to the golf ball and it will travel a greater distance
4. If the golfer wants the ball to travel a specific distance he must perform a specific amount of work, thus applying a force.
Thank you in advance!
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
JaWiB
JaWiB is offline
#2
Jul3-08, 02:16 PM
P: 289
Is there any other way (other than increasing the force on the ball) to make the ball move a greater distance? Or maybe more accurately, is there any other way to transfer more energy to the ball?
tascja
tascja is offline
#3
Jul3-08, 02:46 PM
P: 87
Im not that acquainted with golf; the only thing i can think of is a harder swing. Like the more power the golfer exerts the more energy in his swing??
JaWiB
JaWiB is offline
#4
Jul3-08, 03:55 PM
P: 289
Not necessarily true. Talking about power is getting a bit off topic though; I was actually looking for a more basic answer.
Work depends on two things: the force applied and the displacement of the object over which the force is applied (for constant force in one dimension: Work = Force*distance) So in general, you could apply a larger force or you could apply the same force over a greater distance to increase the work done on an object.
D H
D H is offline
#5
Jul3-08, 04:57 PM
Mentor
P: 14,440
Quote Quote by tascja View Post
That's assuming all other things are equal. A lot of factors beside swing speed affect the distance a ball travels. I don't want to do your homework for you, so perhaps you should think of some of those other factors.
Register to reply
Related Discussions
Relationship between Pressure of Gas and Mechanical Work Introductory Physics Homework 16
work, force, and distance problem Introductory Physics Homework 12
In a Force vs Distance graph, is work the area underneath? Introductory Physics Homework 4
relationship between work and potential energy Introductory Physics Homework 11
Distance relationship between primary/secondary coils Introductory Physics Homework 1
