Thread Closed
spring force
Share Thread Thread Tools
Jul4-08, 03:10 AM   #1
spring force
I need to calculate the spring force required to make a back pressure regulator for fluid control the back pressure must exceed 3bar to open the ball valve the flow rate is 82mls/per min. the bore dia of the inlet is 2 mm dia. any help greatly appreciated
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Jul4-08, 05:49 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
3 bar is 300000 N/m2 and your bore has an area of approximately 3.1 mm2= .00031 m2 so you are talking about a force of approximately 93 Newtons. The flow rate is irrelevant.
Jul4-08, 06:01 AM   #3
Recognitions:
Homework Helper Homework Help
Apply a freebody diagram to your sensing element, including poppet and spring. Diaphragm element area can be estimated by using the average diameter of backing plate diam and clamped diam at body. Don't forget to include poppet area as this is generally significant. Spring load then determines cracking pressure and 'droop'. You need to then determine valve lift above cracking pressure which produces a flow. Is that what you need? Are you familiar with calculating flow from Cv?
Thread Closed
Thread Tools
Similar Threads for: spring force
Thread Forum Replies
Spring Force Help Introductory Physics Homework 2
spring force Introductory Physics Homework 2
spring force Advanced Physics Homework 6
Where does the spring force come from? General Physics 9
Spring Force Advanced Physics Homework 1
