Constraint Forces: Definition & Necessity
The discussion revolves around the definition and necessity of constraint forces within the context of the Lagrangian formulation of mechanics. Participants explore how these forces relate to virtual displacements and the implications for constrained motion in classical mechanics.
  • One participant questions how to define constraint forces and whether virtual displacements must be perpendicular to these forces.
  • Another participant defines constraint forces as those that ensure masses comply with the geometrical configuration of a problem, using the example of a pendulum to illustrate this concept.
  • A further participant seeks clarification on how the definition of constraint forces supports their earlier claim regarding virtual displacements.
  • Another response discusses the relationship between constraint forces and constrained motion, explaining that these forces act to keep objects in specific configurations, such as a ball on a surface.
  • This participant notes that at equilibrium, the force keeping the ball in contact with the surface must act normal to the surface, leading to the conclusion that the dot product of force and virtual displacement is zero.
Participants express varying levels of understanding and interpretation of constraint forces, with some definitions and explanations being contested or requiring further clarification. No consensus is reached on the necessity of the perpendicular relationship between virtual displacements and constraint forces.
Some participants reference specific equations and concepts from classical mechanics texts, indicating that their understanding may depend on particular interpretations of these materials. There is also mention of historical context regarding the development of classical mechanics.
pardesi
the fundamental basis of the lagrangian formulation is the fact that the virtual displacement are perpendicular to the constraint forces
so how does one define constraint forces?
is it necessary for the virtual displacement consistent with the given constraints be perpendicular to the constraint forces?
The constraint forces are those forces that make the masses which you are investigating comply with the geometrical configuration of your problem.
For example, if you are investigating a pendulum where a mass m hangs on a (massless) string of length r, the force of constraint is simply the force that the string excerts on the mass (thereby making sure that it stays at a distance r from the support point).
hmm that's an intuitive def i got that part explain me the other part and how does the definition prove the fact that i claimed?
Pardesi,
You have several questions listed involving forces of constraint- I empathize. Let's see if I can help out with the conceptual foundations. I have the second edition of Goldstein, so the equation numbers I use may be slightly different than yours.
The Lagrangian (and Hamiltonian) formulation is not much different than F=ma. It's just written in a more general framework involving energy. The question "constraint forces" tries to address is:
How can we describe constrained motion using F=ma?
For example, picture a ball rolling on a surface (with gravity present). Gravity acts 'down', yet the ball cannot simply fall, it is constrained to lie on the surface. The problem of constraint forces is used to describe the force keeping the ball on the surface.
Remember, this is classical mechanics and was invented a loooooooong time before people knew about electrons, there was no proof of atoms existing, no theory for the electromagnetic (or even electrostatic) forc. So, we posit that a force constrains the ball to the surface.
The ball (eventually) comes to rest somewhere on the surface- an equilibrium configuration. Thus, the sums of forces and torques is zero. Goldstein then writes Eq. 1-40 (page 16) invoking "virtual work", but it's just another way to write that the system is in equilibrium.
He then posits "the net virtual work of the forces of constraint is zero" without giving any real jusitification. But, it's clear that *at equilibrium*, the force keeping the ball in contact with the surface must act normal to the surface, while the ball can only move tangentially on the surface. So the dot product of force and (virtual) displacement is zero.
The Equation 1-43 to 1-47 are straightforward: 1-46 and 1-47 are just equivalent ways of expressing a differential, with the idea that dt can be eliminated. The text between 1-47 and 1-48 is a discussion of coordinate transformations rather than physics.
Does that help?
Thank you.
  • · Replies 0 ·
