Why is the phase angle not just -90 degrees?
The discussion focuses on the calculation of the phase angle for the expression \(\frac{\omega_n^2}{-\omega^2+j2 \zeta \omega_n \omega}\). The correct phase angle is derived as \(-90 - \tan^{-1} \left(\frac{\omega}{2 \zeta \omega_n}\right)\), rather than simply \(-\tan^{-1} \left(\frac{-2 \zeta \omega_n}{\omega}\right)\). The reasoning involves recognizing that the denominator represents a second quadrant angle, necessitating the adjustment of the inverse tangent function to account for this. The final expression is simplified using the identity \(\tan^{-1}(x) = 90 - \tan^{-1}(1/x)\).
  • Understanding of phase angles in complex numbers
  • Familiarity with the inverse tangent function (arctan)
  • Knowledge of MATLAB, specifically the arctan2() command
  • Basic concepts of damping ratio (\(\zeta\)) and natural frequency (\(\omega_n\)) in control systems
  • Study the properties of complex numbers and their phase representations
  • Learn about the arctan2() function in MATLAB for handling quadrant-specific angles
  • Explore control system dynamics, focusing on damping ratios and their effects on system behavior
  • Investigate phase margin and gain margin in stability analysis of control systems
Control system engineers, electrical engineers, and students studying signal processing or system dynamics who need to understand phase angle calculations in complex expressions.
Cyrus
Can someone show me how they got this:
[tex]\frac{\omega_n^2}{-\omega^2+j2 \zeta \omega_n \omega}[/tex]
Has this phase:
[tex]-90-tan^{-1} \frac{ \omega}{2 \zeta \omega_n}[/tex]
Why isn't it simply:
[tex]0 -tan^{-1} \frac{- 2 \zeta \omega_n}{ \omega}[/tex]
Hi Cyrus. Look at the denominator, it's phase is clearly a "second quadrant" angle. Inverse tan however only covers quadrands I and IV, so you want to express it as 180 - invtan(2 zeta omega_n / omega) right.
Now you're right to do what you did next, subtract the phase of the denom from the phase of the num to get :
-180 + invtan(2 zeta omega_n / omega).
Now just use invtan(x) = 90 - invtan(1/x) to get the desired expression.
BTW. Sorry that I'm too lazy to latex today, I hope you can follow it anyway.
Ah, that makes sense. Thanks uart!
Im so used to using arctan2() command in MATLAB that I forgot all this stuff.
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 0 ·
