What is the Difference Between a Microwave Cavity and Chamber?
The discussion revolves around the distinction between microwave cavities and microwave chambers, focusing on their definitions, functions, and implications in cooking and material research. Participants explore the technical aspects of resonance and its relevance to both terms.
  • One participant expresses confusion about the terms "microwave cavity" and "microwave chamber," suggesting that resonance should be avoided in cooking chambers.
  • Another participant questions the assumption that a chamber is not a cavity.
  • A mention of an "anechoic chamber" used for testing microwave devices is introduced, implying a different context for cavities.
  • One participant proposes that a chamber may function as an untuned cavity to prevent resonance, while a resonant cavity is used for research purposes.
  • Another participant argues that the microwave chamber meets the criteria of a resonant cavity, noting the presence of dead spots due to the stirrer mechanism in modern microwaves.
  • Discussion includes the variability in microwave sizes and the impact of design on cooking efficiency, with references to patents and different models.
  • Some participants highlight that all microwaves operate at the same frequency but differ in design, affecting how they handle cold spots.
  • One participant emphasizes that the microwave chamber produces standing waves due to reflections, reinforcing the idea of it being a resonant cavity in a different context than that of a klystron.
Participants do not reach a consensus on whether a microwave chamber can be classified as a resonant cavity. Multiple competing views are presented regarding the definitions and functionalities of both terms.
Participants express varying assumptions about resonance and its implications for microwave chambers versus cavities. The discussion reflects a range of interpretations regarding the technical definitions and applications of these terms.
hydro2008
hi ,
I am confused with these two terms microwave cavity and
microwave chamber . Some say that the microwave chamber
inside which food gets cooked acts like a resonant cavity
( which I believe is not true ) because resonance must best be
avoided inside the chamber .Resonance I think takes place only in
a cavity . thanks
hydro2008
Science news on Phys.org
What makes you think that the chamber is not a cavity?
There is an "anechoic chamber" used a lot in testing microwave devices.
well , this is my simple understanding . A chamber may be an untuned cavity where reverberation or resonance does not take place. It is strictly to be avoided in order to maintain the same cooking power levels. A resonant cavity where resonance can hasten heating is used for materials R&D to estimate the dielectric loss factor of specific materials . see http://www.msi-sensing.com/microwave_cavity.htm
I might be totally wrong here . I am wondering if the chamber could be made much smaller without encountering resonance with thick steel and without any transparent window for a specific application .
First off, I want to differentiate between the resonance that creates the microwaves in the klystrom and the resonance that occurs in the microwave chamber.
I believe that the microwave chamber does indeed meet the requirements of a resonant cavity.
The reason that you do have dead spots inside the chamber is because most modern models have something called a "stirrer" that slightly reflect the microwaves as they leave the waveguide, slightly altering the resonant conditions inside the cavity. If you didn't do that, or didn't rotate the food, cold spots would result.
Ever notice that microwaves do not come in "all sizes"? Rather they are dictated by the wavelength used, which is in turn dictated by the economics of wavelength used in the industry. S-waves can be slightly adjusted, perhaps by a dielectric or somesuch, and thus there is a tiny variation in microwave sizes, but they do not run the gambit.
microwaves come in various volume sizes .I have a large convention
microwave sitting in the kitchen much larger than an ordinary microwave. Recently I read a patent about
a cylindrical space saving design for a microwave . The larger and smaller ovens use the same
2.5 Ghz frequency . The stirrer blade assembly however is present only in a few models and not all
ovens have them .
2.5 Ghz frequency.
The size variation is nothing like the size variation that you see in more conventional ovens, where you can go from a chamber an inch across to huge ovens where they cure petrochemical pipes, gun barrels and such. The variation is pretty continuous.
For microwave ovens, the fundamental nature of the microwave is important to the chamber design.
ovens have them .
Some have rotating plates which serves the same purpose. All must deal with the problem of "cold" spots in some manner. Maybe there are other methods as well.
I've brought this up to reinforce the notion that the microwave chamber is a resonant cavity, not in the sense that a klystron utilizes resonance, but in the fact that there are reflections at the chamber walls, producing three dimensional standing waves and such.
  • · Replies 30 ·
17K
  • · Replies 73 ·
10K
  • · Replies 20 ·
