| Thread Closed |
Ideal gas law constant R conversion |
Share Thread | Thread Tools |
| May6-04, 11:01 AM | #1 |
Hi, not sure if this is the right forum to ask this in, but I was trying to convert the ideal gas law constant R (from PV = nRT) from:
8.31 (Pa * cu. meters) / (mol * Kelvin) to the equivalent: 10.73 (psia * cu. ft) / (lb. * mol * Rankine) Here's the conversion factors I've been using: 1 Pa = 1.4505E-7 psia (absolute pressure) 1 cu. meter = 35.315 cu. ft 1 Rankine = 1.8 Kelvin What I don't understand is where does the extra pounds in the denominator of the 10.73 value come from? This is probably what's throwing off my calculations. -Thanks |
| May6-04, 12:27 PM | #2 |
Mentor
In the first equation "mole" means "gram-Mole"; in the second the unit is "lb-Mole". You need to convert between gm-Moles and lb-Moles.
| May6-04, 10:37 PM | #3 |
Ahh, using 1 gram = 0.0022 lb I finally got it. Thanks alot, this has really been bugging me
| May7-04, 09:50 AM | #4 |
I always use this
[tex]R = 0.082 \frac{atm \cdot l}{mol \cdot K} = 2 \frac{cal}{mol \cdot K} = 8.314 \frac{J}{mol \cdot K} [/tex] |
| Jul29-04, 04:23 PM | #5 |
PDAcalc units This program runs on a palm, PocketPC,windows and will do all the conversions AUTOMATICALLY for you. Download the user manual which has an example of the PV = nRT formula that shows how it automatically convert between the different units. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Ideal gas law constant R conversion
| Question regarding ideal fluids vs. non-ideal fluids | General Physics | 3 | ||
| Constant Volume/Ideal Gas | Introductory Physics Homework | 1 | ||
| constant velocity or at constant acceleration | General Physics | 3 | ||
| Is Boltzman's Constant related to the Fine Structure Constant? | Quantum Physics | 6 | ||
| Connection of Newtonian Constant of Gravitation G and Plank Constant h | General Physics | 11 | ||
