Electric Field of Dipole, straight line, ring, disk, shell, and sold sphere
The discussion focuses on deriving the electric field generated by various charge distributions, including dipoles, lines, rings, disks, shells, and solid spheres. Key equations mentioned include the electric field due to a point charge, expressed as kQ/r², and the differential electric field formula dE = dq/(4πεr²). The importance of charge density concepts, such as linear charge density (λ) and volume charge density (ρ), is emphasized for accurate calculations. Participants highlight the necessity of understanding the spatial relationship between the charge distribution and the point of interest in the electric field calculations.
  • Understanding of electric field concepts and Coulomb's law
  • Familiarity with charge density definitions: linear (λ), surface, and volume (ρ)
  • Knowledge of vector calculus for spatial coordinates (x, y, z)
  • Basic proficiency in physics equations related to electrostatics
  • Study the derivation of electric fields for point charges and dipoles
  • Learn about the application of Gauss's law in calculating electric fields
  • Explore the concept of electric field lines and their significance in electrostatics
  • Investigate the effects of charge distribution on electric fields in different geometries
Students studying electromagnetism, physics educators, and anyone seeking to understand electric field calculations for various charge distributions.
Dottywine
Okay, I totally do not understand how to derive the electric field made by a dipole or a line or a ring or etc.
When finding the electric field, when you make an estimate, saying that the test charge is very far away, it should be similar to kQ/r^2
You may need to know lambda, the linear charge distribution and the ones for area and volume.
I've made lots of attempts. Its 2 am right now, but I will upload it tomorrow if anyone needs it. Someone asked a question like this before, if that helps, but I didn't understand the answer and I need help with all of these things.
You have to be more specific if we are to help. But in general, you should make use of this:
[tex]dE = \frac{dq}{4\pi \varepsilon r(x,y,z)^2}[/tex]. But you probably already knew that. r(x,y,z) is just the distance from the point at which you want you find the E-field to the differential charged element dq in terms of x,y,z coordinates. dq is either lambda dL, rho dV where lambda and rho are the charge densities of the charged object.
And I don't think you need to make any assumption about the test charge being very far away. There are a number of such problems in this forum recently. Do a search of this and you'll find some of them.
  • · Replies 27 ·
  • · Replies 68 ·
9K
  • · Replies 17 ·
