Different Type of Extension Problem for Groups
  • Context: Graduate
  • Thread starter Thread starter Hello Kitty
    Extension Groups Type
This discussion focuses on the extension problem for finite groups, specifically examining the conditions under which two groups, H and K, can be embedded as subgroups of a group G such that G equals the product HK with a trivial intersection. Unlike the traditional extension problem, this scenario does not require K to be a normal subgroup or for G/K to be isomorphic to H. The conversation suggests that there may be established theories surrounding these types of extensions, particularly regarding the automorphisms of the subgroups involved.
  • Understanding of finite group theory
  • Familiarity with normal subgroups and their properties
  • Knowledge of semidirect products in group theory
  • Concept of group isomorphism and automorphisms
  • Research the theory of group extensions and their classifications
  • Explore the properties of semidirect products in finite groups
  • Study automorphisms and their impact on subgroup structures
  • Investigate existing literature on non-normal subgroup embeddings
Mathematicians, particularly those specializing in group theory, algebraists, and researchers interested in the structural properties of finite groups and their extensions.
Hello Kitty
Let H, K be finite groups.
Instead of asking what groups G there are such that K can be embedded as a normal subroup and G/K is isomorphic with H (the usual extension problem for groups), I've been thinking about the following:
Which groups G exist such that H and K can be embedded as (not necessarily normal) subgroups such that G=HK where H and K have trivial intersection?
This neither contains nor is contained in the usual extension problem since there there is no requirement for the normal subgroup to have a complement, and here we don't require any of the factors to be normal.
Clearly for a given G with relevant subgroups identified, there exist cases where we could replace one of the subgroups by a conjugate (e.g. the complement of a semidirect product). Perhaps we could even do the same with an isomorphic non-conjugate. This leads me to think that perhaps some of these 'extensions' should be in some sense 'isomorphic' or 'equivalent'.
I guess my first question before I go any further is is this already an established theory? (It must be.)
If you start with ##H,K## and build ##G=HK## then ##G\cong H \times K## will do and solve your problem. In all other cases, the real question is how the subgroup operates on the normal subgroup. Any different automorphism results in a different example. The direct product is the trivial automorphism which always works.
  • · Replies 26 ·
  • · Replies 19 ·
