Pressure at the bottom of a container
  • Thread starter Thread starter Spirochete
    Container Pressure
The pressure at the bottom of an open glass container filled with 0.10 m of oil (density 850 kg/m³) and 0.20 m of water (density 1000 kg/m³) is calculated using the formula P = ρgh. The total pressure at the bottom is the sum of the pressures from both fluids, which requires calculating the pressure contributions separately for the oil and water, and then adding atmospheric pressure (1 atm) to the final result. The correct depth for the oil is 0.10 m, not the combined height of both fluids.
  • Understanding of fluid mechanics principles
  • Familiarity with pressure calculations in fluids
  • Knowledge of density values for common liquids
  • Ability to apply the hydrostatic pressure formula P = ρgh
  • Study hydrostatic pressure calculations in various fluid scenarios
  • Learn about the effects of atmospheric pressure on fluid systems
  • Explore the concept of buoyancy and its relation to fluid density
  • Investigate real-world applications of fluid pressure in engineering
Students in physics or engineering courses, educators teaching fluid mechanics, and professionals involved in hydraulic systems or fluid dynamics.
Spirochete
In an open glass container, 0.10 m of oil (rho=850 kg/m^3) floats on top of 0.20 m of water (1000 kg/m^3). What is the pressure at the bottom of the glass?
(rho)(h)(g)= pressure at a depth of h
The only thing I'm not sure of is: for the oil, should I consider h to be o.1 m, or the sum of both heights, making h 0.3?
edit: I also know i have to add in 1 atmosphere at the end
Each fluid gets its own "height". You'll find the sum of both pressures, not heights.
  • · Replies 63 ·
