Specific Heat Capacity question
The problem involves calculating the final temperature when two quantities of water at different temperatures are mixed. The subject area is thermodynamics, specifically focusing on the concept of specific heat capacity and the conservation of energy.
  • The original poster attempts to apply the concept of specific heat capacity to find the final temperature but questions the validity of their result. Another participant identifies a mistake related to the Law of Conservation of Energy and proposes a revised equation for heat change.
Participants are actively engaging with the problem, with one offering a correction to the original approach and suggesting a new calculation. There is a recognition of the need to account for energy conservation, leading to a different conclusion about the final temperature.
Participants are discussing the assumptions related to the specific heat capacity of water and the implications of mixing equal volumes at different temperatures. The original poster's confusion about the outcome indicates a need for clarification on the principles involved.
Sabellic
If 100 mL test of water at 60°C is added to 100 mL of water at 20°C, then the final temperature of the water will be?
c=Specific Heat Capacity
Specific Heat Capacity of water = 4186
Quantity of Heat Energy=mass * Specific Heat Capacity of substance * temperature difference
-or-
Q-=m*c*temp diff
100mL=0.1 kg
Water quantity at 60 degrees + Water quantity at 20 degrees = sum water quantity at new temperature
0.1 kg * 4186 * (60 - final temp) + 0.1 kg * 4186 * (final temp - 20) = 0.2 kg * 4186 * final temp
418.6 (60-final temp) + 418.6 (final temp-20) = 837.2 * final temp
25116 - 418.6final temp + 418.6final temp - 8372 = 837.2final temp
16744=837.2final temp
final temp= 20 degrees celsius
So, the final temp is 20°C ? that doesn't make sense?
Oh hold on now. I think I see my mistake. I didn't account for the Law of Conservation of Energy.
Final Heat Change of 60°C Water + Final Heat Change of 20°C Water = 0
0.1 kg * 4186 * (final temp-60) + 0.1 kg * 4186 * (final temp - 20)=0
418.6 (final temp) - 25116 + 418.6 (final temp) - 8372 =0
837.2 (final temp) = 33488
final temp = 40
Therefore, the final temperature of the water is 40 °C
Yes, the final temperature should be 40oC, and your work is correct.
