Springs - simple harmonic motion
To find the work done on a spring when only the distance (x) is provided, the spring constant (k) is essential, as it relates to the force exerted by the spring. The work done can be calculated using the formula W = 1/2 kx², but without k, the calculation cannot proceed. The discussion raises concerns about the lack of information in the problem, particularly regarding the pressure gauge's function and how it relates to the work done by air pressure. Clarification is sought on whether additional context or diagrams are available to better understand the scenario. Overall, the inquiry highlights the need for more details to accurately determine the work done on the spring.
tascja
my question is: is there a way to find the work done to a spring when the only variable given is the distance (x)??
For the pressure gauge, what work is done by the air on the spring?
W = 1/2kx2
Fx = kx
I can't really attempt anything because i don't have k, its not given and I am not sure how to find it??
If it is a pressure gauge what is it you would expect such a device to do? Will it measure say something like the pressure of the air? When it does that will it give a reading? What work will the air have done to affect that reading from the normal state?
Is there a diagram and more to the problem or just a general question about what work air pressure does inside a gauge?
The question doesn't give any other information so i think your right, they just want a general answer. thanks i was freaking out because they didnt give enough info!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
