Analyzing Errors in Converging Lens Calculations
The discussion revolves around the analysis of errors in calculations involving a converging lens, specifically focusing on the determination of focal distance and magnification. The original poster reports discrepancies between two methods of calculating magnification, leading to questions about potential sources of error and methods for error analysis.
  • Participants inquire about the specific distances measured in the experiments and suggest that inaccuracies in measurements or lens thickness could be contributing factors to the divergent magnification results. The original poster seeks guidance on mathematical theories related to error analysis.
The discussion includes attempts to clarify the nature of the problem and explore potential errors. Some participants provide foundational concepts in error analysis, while the original poster expresses gratitude for the insights shared. There is an ongoing exploration of how to interpret the results and the implications of measurement errors.
The original poster notes a lack of formal education in error analysis, which may influence their understanding of the concepts being discussed.
kthouz
My task was to determine the focal distance and the magnification of a converging lens. I've done everything as stated in the procedure. The problem that i have is that when i am calculating the magnification in two differents ways i.e M1=b/a and M2=h'/h where a=distance form object to mirror, b=distance from image to mirror, h=height of the objet and h' height of the image, those two magnifications are very divergent. for example in 5 trials if i choose two : M1= 2 while M2=0.95
M1=1.57 while M2=0.85
So how can i explain it? Can you give me a hint or just some error analysis methods (link if possible)? Cause I've never get a course about how to analyse errors.
That's strange. Just what are the 4 distances involved in your experiments? (Image distance, object distance, image height, object height)
Possible errors are either inaccuracies in the measurements, or that the object or image distance is comparable to the lens thickness (the lens should be much thinner than either distance for the calculations to work out simply).
But do you know any mathematical theory used in error analysis so i can try to interpret my results? Please give me a refence!
The simplest theory works as follows:
When you are adding or subtracting two numbers, the error of the result is the sum of the errors.
When multiplying or dividing two numbers, the percentage error of the result is the sum of the percentage errors.
There are more complicated ways of calculating errors, but if you're new to error analysis I would use this simple method.
Example 1, adding or subtracting numbers:
[tex] (5.0 \ \pm \ 0.3) - (2.0 \ \pm \ 0.1) = 3.0 \ \pm \ (0.3 + 0.1)<br /> = 3.0 \ \pm \ 0.4[/tex]
Check by adding or subtracting errors from terms, in order to get the maximum result possible:
(5.0 + 0.3) - (2.0 - 0.1)
= 5.3 - 1.9
= 3.4
This "maximal error" calculation gives an answer that is 0.4 higher than the original calculation of 3.0, so the calculated error of 0.4 is correct.
Example 2, multiplying or dividing:
[tex] \frac{6.0 \pm 0.5}{2.0 \pm 0.1} = 3.0 \ \pm \ ?[/tex]
To find the error, add the percentage or fractional errors:
[tex] \frac{0.5}{6.0}\ 100 \ + \ \frac{0.1}{2.0} \ 100[/tex]
= 8% + 5% = 13%
So the error is 13% of 3.0:
0.13 x 3.0 = 0.39 or roughly 0.4
The final answer is
[tex]3.0 \pm 0.4[/tex]
Check the result by adding or subtracting errors to produce the maximum result possible:
[tex] \frac{6.0 + 0.5}{2.0 - 0.1} = \frac{6.5}{1.9} = 3.42...[/tex]
This result is 0.4 higher than 3.0 (to the nearest 0.1), so the calculated error of 0.4 is correct.
Hope that helps.
Thank you very much!
  • · Replies 17 ·
10K
  • · Replies 21 ·
15K
