Is Your Point Inside a Non-Regular Tetrahedron?
  • Context: Undergrad
  • Thread starter Thread starter soikez
    Points
To determine if a point is inside a non-regular tetrahedron, one effective method involves calculating the volumes of sub-tetrahedra formed with the point and the tetrahedron's vertices. If the sum of these volumes equals the volume of the original tetrahedron, the point lies inside. This approach is analogous to the area method used for triangles, where the sum of areas of sub-triangles equals the area of the original triangle. The discussion references a method suggested by Asuralm for volume calculations.
  • Understanding of tetrahedral geometry
  • Familiarity with volume calculations
  • Basic knowledge of geometric properties of shapes
  • Ability to perform mathematical proofs
  • Research methods for calculating the volume of a tetrahedron
  • Learn about barycentric coordinates for point-in-polyhedron tests
  • Explore computational geometry algorithms for spatial queries
  • Investigate applications of tetrahedral geometry in computer graphics
Mathematicians, computer scientists, and engineers working with geometric computations, particularly those involved in 3D modeling and spatial analysis.
soikez
Hello ,
does anybody knows how can I check if a point is inside a tetrahedral. The tetrahedral isn't regular.
Thanks!
Mathematics news on Phys.org
I don't know if this is a good way to solve it. But if in a triangle, the easiest way to check if a point is inside is to check the sum of the area. i.e. for ABC, there is a point P, if P is inside ABC, then, area(ABP)+area(ACP)+area(BCP) = area(ABC).
You can check the volume in the tetrahedral case.
