Thread Closed
Tesla Turbine, or variation of it.
Share Thread
Jul14-08, 10:04 PM   #1
As I understand it, a tesla turbine runs by injecting steam, or some other gas onto the outside of several disks mounted parallel to each other on a shaft. The gas is directed roughly tangent to the outside of the disks and it exits through openings in the center of the disks. Seems straight forward and all, but somewhat counter intuitive that expanding steam/air/whatever has to squeeze into a smaller space as it migrates towards the center. If it speeds up to compensate for the smaller space, it is 'fighting' against a slower turning surface towards the center of the disks.
I have thought about a similar turbine but instead of having preheated steam injected at the outside the whole disk assembly is heated to the point that it will boil water injected at the center. The steam that is boiled off after hitting the hot disks will not do a whole lot as I have described it so far. What I envision is having 'stators' between each disk. These stators would be spiral shaped from the center out to direct the steam in a manner to cause the disks to turn from the friction of the steam against them. The stators would be shaped in a way to take advantage of the steams expanding volume as it migrates towards the outside. Functionally doing the same thing that a conventional steam turbines stator and rotor blades do by changing shape to take advantage of expanded steam as it gets closer to the exhaust. As for sealing between the stator and rotor? So far my only idea is simply a close fit that does not contact. Efficiency may be ridiculously low, but I just am wondering about concept.
Am I missing something in a conventional tesla turbine? I see reports of efficiencies that are all over the place but you cannot really believe what you read on Nikola Tesla since there are alot of nut-cases out there that worship anything connected to him.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jul15-08, 11:11 AM   #2
Recognitions:
Homework Helper Homework Help
Something like that can certainly work. It's not a tesla turbine, but an aeopile. People generally try to avoid having fast moving (high strain) and high temperature at the same place/time because it's a materials challenge.
Jul15-08, 11:31 AM   #3
Hello Nate. Thanks for the reply. Yes I am sure it is a materials challenge. I'm not too serious about this, just something that crossed my mind. There are plenty of challenges that would be in the way. I'll give more details later on the idea.
Jul16-08, 12:03 AM   #4
Actually upon further investigation what I have described is NOT an aeopile. If the spiral shaped stators I referred to turned with the disks then yes it would be an aeopile. My idea is to try to keep all the heat in one place. The turbine itself is the boiler. Let the water turn to steam as it contacts the disks and stators. With the properly shaped stators the disks should turn.
Jun24-09, 03:26 AM   #5
i am doing tesla turbine 3D simulation in CFX-11,HOW TO CREATE 3D geometry,i didnt get any idea
Jun24-09, 06:02 AM   #6
Recognitions:
Gold Membership Gold Member
Quote by Averagesupernova View Post
As I understand it, a tesla turbine runs by injecting steam, or some other gas onto the outside of several disks mounted parallel to each other on a shaft. The gas is directed roughly tangent to the outside of the disks and it exits through openings in the center of the disks. Seems straight forward and all, but somewhat counter intuitive that expanding steam/air/whatever has to squeeze into a smaller space as it migrates towards the center. If it speeds up to compensate for the smaller space, it is 'fighting' against a slower turning surface towards the center of the disk.
I have never noticed this thread until now, it might help to consider what volume the gas requires if it has given up it's energy, to the work transfered through the spinning disc group.
Jun24-09, 06:35 AM   #7
There is a pretty active bunch of experimenters on Yahoo...
http://groups.yahoo.com/group/TheTeslaTurbineList
Thread Closed
Similar discussions for: Tesla Turbine, or variation of it.
Thread Forum Replies
Tesla Turbine applications Mechanical Engineering 9
Francis Turbine And Kaplan Turbine Doubt Mechanical Engineering 11
Tesla Turbine Efficiency Engineering Systems & Design 92
Tesla: The New Wizard General Discussion 8
Tesla Coils Introductory Physics Homework 6
