Cut a Vent in SolidWorks When Face is Broken
  • Thread starter Thread starter 00PS
    Solidworks
The discussion revolves around the challenges of modifying a SolidWorks model imported from an IGES file, specifically regarding cutting a vent in a case with a mounting flange. Participants explore various methods to achieve the desired modification, including sketching and extrude-cutting, while addressing the limitations of the file format.
  • Homework-related
  • One participant suggests creating a sketch and using an extrude-cut to remove the mounting flange.
  • Another participant proposes cutting the flange using a similar shape if deletion is not possible.
  • Some participants express concerns about the difficulties of modifying IGES files and recommend converting the model to a native SolidWorks format or a parasolid for easier manipulation.
  • There is a suggestion to sketch on a plane perpendicular to the flange to outline the area to be cut off, though uncertainty remains about the feasibility of this operation on an IGES model.
  • A participant mentions having DWG/DXF drawings and inquires if these provide easier solutions, expressing a need for more detailed guidance due to their lack of experience with SolidWorks.
  • Another participant notes the challenges of providing a click-by-click tutorial without familiarity with SolidWorks and emphasizes the importance of learning the basics of solid modeling.
  • In a separate thread, a participant discusses difficulties with creating closed-end coils in SolidWorks 2000, noting limitations in that version compared to later editions.
Participants generally agree that modifying IGES files presents challenges, and multiple competing views remain regarding the best approach to cut the vent and the feasibility of using different software or file formats. The discussion about creating springs indicates a separate unresolved issue regarding version limitations.
Limitations include the uncertainty about the capabilities of IGES files in SolidWorks, the need for specific software knowledge, and the challenges faced by participants with varying levels of experience in solid modeling.
00PS
Basically, I am trying to cut out a vent for a fan. The vent feature of SW requires the vent to be on a single face, and in this case it is not. The bottom half of the case has a mounting flange (highlighted green in attached image), so I cannot place the vent where I need to. The model was imported from a .igs file and I cannot simply "delete" the feature. How can I remove the highlighted portion and extend the face across the deleted portion to create a contiguous face to cut the vent?
Looks to me like you'll have to do a sketch and then extrude-cut.
a little confused...A sketch of what? Can you be more descriptive?
Thanks.
If you can't delete that part, "cut(subtract)" that part using a similar shape, that's what he meant.
In my experience, IGES files are very difficult to modify with new features (removing or adding). I would first see if you can get the model in a native format to Solidowrks, or at least a parasolid.
Basically, you have to "cut" the mounting flange off by sketching on a plane that is perpandicular to it, and create an outline that follows what you want to cut off. I'm not 100% this operation can be preformed on an IGES model however...
I have access to SolidEdge, would it be easier to make the adjustments in that environment?
Solidworks isn't the problem, IGES files are. If after you try you are unable to remove the flange with an extrude-subtract operation (or other method), I would recommend getting the model in another format.
I now have DWG/DXF drawings of the assembly, are their easier solutions now? I don't quite follow you on your solution (and to be honest would need a click by click walkthrough). This whole ordeal has been my first time using SW and without any sort of drafting knowledge I am lost to say the least. Thank you for your patience.
Well, I don't have Solidworks so I can't help you with a click-by-click tutorial (since you have no modeling experience, I'm not sure it would help much anyway). Basically, you'll either need to find someone who knows enough about solid modeling and drafting to do it, or you'll need to learn the basics of solid modeling to do it yourself. While not very difficult (Solidworks is quite easy to learn IMO) it will take a certain type of thought process which seems to be escaping you thus far...
Teaching you how to model and draft is imposible through a forum, I'd suggest studying on-line Solidworks tutorials, and consider buying a book at your local bookstore or at Amazon.com.
Looks like a useful website:
http://www.3dcadtips.com/go.php?topic=2&cat=772"
I have a problem when it comes to drawing springs. I've grasped the basic springs. I'm trying to create a closed end coil but it's not right. I'm basically adding another coil with a smaller pitch but there's no smooth transition in the wire. looks broken. I have solid works 2000. does anyone have any suggestions?
Can you post a picture that illustrates the problem you're having?
I think I've found the answer in another thread. Apparently you cannot do the varying pitch springs with the s/w 2000 edition. You can with 2006 though.
  • · Replies 39 ·
17K
  • · Replies 19 ·
11K
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 26 ·
