What Determines the Radius of Water Drops from a Spinning Umbrella?
  • Thread starter Thread starter shad0w0f3vil
    Water
The radius of water drops from a spinning umbrella is determined by the principles of rotational kinematics and equations of motion under a uniform gravitational field. When an umbrella rotates at one revolution per second, the radius of the circle formed by the drops can be calculated using the centrifugal force acting on the water drops. Kepler's laws are not applicable in this scenario, as they pertain to planetary motion rather than the dynamics of rotating objects.
  • Understanding of rotational kinematics
  • Familiarity with equations of motion in a gravitational field
  • Basic knowledge of centrifugal force
  • Ability to apply mathematical concepts to physical scenarios
  • Research the equations of motion under uniform gravitational fields
  • Study the principles of centrifugal force and its applications
  • Learn about rotational kinematics and its mathematical formulations
  • Explore practical examples of rotating systems and their effects on objects
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating systems and fluid motion.
shad0w0f3vil
Hi there,
I received this question and was rather confused as to how to apporach solving it:
Water drops shaken off the rim of a rotating umbrella meet the ground in a circle. If you rotated an umbrella making one revoution per second, what would you expect the radius of the circle formed by the drops to be. Justify all values used and define all variables.
I tried to draw a diagram labelling the radius of the umbrella as x and the radius of the drops as x+y and use Keplers's third law of planetary motion, but was unsuccessful. Any help would be greatly appreciated.
Cheers
Kepler's laws of planetary motion have nothing to do with this. Equations of motion under a uniform gravitational field and rotational kinematics likely do. Can you make a better try at this?
i will look it up thanks
  • · Replies 40 ·
  • · Replies 16 ·
11K
