Thermodynamics/Gas Law questions
  • Thread starter Thread starter Carbonoid
    Law
This discussion focuses on solving two thermodynamics problems related to ideal gases. For the first question, the user correctly applied the ideal gas law (n = PV/RT) to determine the number of moles of gas as 22.22. To find the mass, they need to multiply the number of moles by the molecular weight of 352 g/mol, resulting in a mass of 7777.84 grams. The density can then be calculated using the formula density = mass/volume. In the second question, the user attempted to find the volume change using the equation P1/T1 = P2/T2, leading to the conclusion that the volumes remain approximately the same.
  • Understanding of the Ideal Gas Law (PV = nRT)
  • Knowledge of thermodynamic principles, specifically gas laws
  • Familiarity with unit conversions, particularly between Kelvin and Celsius
  • Basic algebra for manipulating equations
  • Learn how to calculate mass from moles using molecular weight
  • Study the derivation and applications of the Ideal Gas Law
  • Explore the relationships between pressure, volume, and temperature in gas laws
  • Investigate real gas behavior versus ideal gas assumptions
Students and professionals in physics, chemistry, and engineering fields, particularly those studying thermodynamics and gas laws.
Carbonoid
Hi,
I'm stuck on two questions, I gratefull if someone could help me with them, firstly;
(Q1) "A cubical container of volume 0.10m^3 contains a gas at 300K and 1000000Pa. Assuming that the gas is ideal, determine
a) the number of moles of gas present, given that the Universal Gas constant is 8.3 J/K/mol.
b) the mass of gas present given that its relative molecular mass is 352.
c) the density of the gas"
I'm okay I think working out 1a I used the equation n=PV/RT and got 22.22. I can't seem to find how to work out the mass...and 1c I think I'm okay, I guess I just use M/V.
Secondly;
(Q2) "A fixed mass of gas in passing through a jet engine has its pressure increased from 300000 to 1300000Pa, while its temperature rises from 80(deg C) to 1500 (deg C). By what factor does the volume of gas change?"
I worked out an answer to this but it looks wrong, I used P1/T1 = P2/T2 and found the difference between those two to be 116.638, so is that the correct method to work out the change of volume?
Thanks again
(1) Hint: What is the mass of one mole of a material with molecular weight 352?
(2)[tex]\frac{P_1V_1}{T_1}=\frac{P_2V_2}{T_2}[/tex] so [tex]\frac{3 \times 10^5 V_1}{353}=\frac{1.3 \times 10^6 V_2}{1773}[/tex] so [tex]V_1=\frac{353 \times 1.3 \times 10^6} {1773 \times 3 \times 10^5} V_2 \approx \frac{5 \times 10^8}{5 \times 10^8} V_2 = V_2[/tex]
so I get that they should be roughly the same.
hey thanks, I get it now
  • · Replies 25 ·
  • · Replies 17 ·
