Can Shock Waves Exist in Different Reference Frames?
This discussion centers on the existence of shock waves in different reference frames, particularly in a supersonic flow scenario on Mars. The experiment involves observing a sphere in a supersonic storm and measuring pressure around it. The key conclusion is that while shock waves may not be visible in a subsonic reference frame, the underlying thermodynamic properties, such as entropy and pressure loss, remain invariant across frames. Ultimately, the relative motion between the sphere and the gas is what determines the presence of shock waves, confirming that they exist regardless of the observer's frame of reference.
  • Understanding of shock wave theory
  • Familiarity with reference frames in fluid dynamics
  • Knowledge of thermodynamic properties, specifically entropy and pressure
  • Basic principles of Galilean velocity composition
  • Explore the principles of shock wave formation in supersonic flows
  • Study the effects of reference frames on fluid dynamics
  • Learn about entropy changes in compressible flow
  • Investigate Galilean transformations and their applications in fluid mechanics
Physicists, fluid dynamicists, and engineers interested in the behavior of shock waves and reference frame effects in supersonic flows.
Clausius2
Ok, imagine this experiment:
I am in Mars, inside of a supersonic storm. There is a small sphere standing inside the incident flow, and I am in a laboratory viewing the shock wave caused by the sphere. I have some pressure measurements of the flow, (i.e around of the sphere surfice), so I can demostrate the shock wave presence.
At this point, I have the idea of choosing a different reference frame for extracting measurements. I choose just a reference frame where I can see the flow being completely subsonic (i.e. the laboratory translates at some speed so that viewing is possible, by means of a galilean velocity composition). If the flow is subsonic, no shock wave will be seen at all. I suppose (certainly?) that static pressure and entropy measurements are not a function of the reference frame chosen, so I will have the same experimental figures of the first case, where the flow was supersonic.
I mean, in some reference frame I will see a shock wave, and in another I will not see one. But we know that a fluid throug shock waves have an increasing in its entropy and a strong pressure loss. This two properties are not a function of a reference frame, because are local thermodynamic properties of the flow.
What happens? Is there a shock wave? How could I demostrate that in these two laboratories?
I believe you got yourself a bit confused by this one,
happens to me too. :smile:
In a "different" reference frame the relative speed between
your sphere and the gas will still be supersonic and that's
ALL you need to look at. As for the movemnt of the
gas itself - it doesn't matter weather an object moves
through the gas or the gas past the object - on a
windy day you can see that a bird can stay in one
spot or a model airplane can fly very slowly upwind and
very fast downwind - this is because the amount of
lift is constant, and lift depends on RELATIVE motion between
the geometry creating lift - object, and the gas(/liquid).
Live long and prosper.
Hi drag,
Probably you are right. So I would see a traveling shock wave.
  • · Replies 18 ·
  • · Replies 236 ·
18K
12K
