Optimization: Minimum Surface Area
The discussion revolves around an optimization problem involving a hexagonal prism capped by a trihedral pyramid. The objective is to minimize the surface area of the combined shapes while maintaining a constant volume. Key variables include the surface area (A), the side length of the hexagon (a), the height of the prism (h), and the displacement (x).
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the need for a secondary equation related to the height (h) and displacement (x) to facilitate the optimization process. There are attempts to derive expressions for volume and height based on the shapes involved, and questions arise about handling derivatives with multiple variables.
The discussion is active, with participants exploring different equations related to volume and surface area. Some guidance has been provided regarding the relationship between the variables, particularly emphasizing that volume is constant, which simplifies the problem to one variable.
Participants are navigating the complexities of combining the volumes of two different geometric shapes and ensuring that the optimization adheres to the constraints of the problem. There is an emphasis on deriving relationships between the variables based on the given conditions.
JoeyC2488
I need help on an optimization problem involving a hexagonal prism with no bottom or top, but the top is covered by a trihedral pyramid which has a displacement, x, such that the surface area of the object is at a minimum for a given volume. The assigned variables include:
A= the surface area of the object
a= the length of each side of the hexagon (a=1)
h= the height of the prism
x= displacement
Given that A= 6(ah-1/2ax) + 3a[tex]\sqrt{3}[/tex]*[tex]\sqrt{x^2+(a^2/4)}[/tex], use calculus to find the displacement, x that yields the minimum surface area. Calculate x if a=1.
I'm struggling trying to find a secondary equation for this optimization problem and I think I need to use an equation evolving h, but I'm not sure what.
The volume V is to be constant, this will lead you to an equation in h and x, from which you may find an expression for h.
How would I use a formula for volume since the problem works with two shapes.
V=(3[tex]\sqrt{3}[/tex])/2 a^2*h
h= V/ (3[tex]\sqrt{3}[/tex]/2 a^2*h
Then, I can just plug this into the first equation, simplify, and start the calculus. Is that right?
Your TOTAL volume is the sum of the prism's volume and the pyramid's volume.
That is the equation in h and x you are to set up!
Your total volum is therefore:
[tex]V=\frac{3\sqrt{3}}{2}a^{2}h+\frac{1}{3}\frac{3\sqrt{3}}{2}a^{2}x\to{h}=\frac{2V}{3\sqrt{3}a^{2}}-\frac{x}{3}[/tex]
So after substituting that in for h, the simplified form would be:
A= 4V-5x[tex]\sqrt{3}[/tex]+ 9[tex]\sqrt{x^2+4}[/tex]
[tex]\sqrt{3}[/tex]
How would I take the derivative of this equation then with multiple variables?
You only have one variable, x. Remember, V is a constant!
  • · Replies 33 ·
15K
