Kinetic Energy and Inelastic Collisions
The discussion centers around the concept of kinetic energy (KE) and its conservation during inelastic collisions. Participants explore the definitions and implications of inelastic collisions, the relationship between momentum and kinetic energy, and the reasons why kinetic energy is not conserved in such events.
  • Some participants question why kinetic energy is not conserved in inelastic collisions, suggesting that this is a fundamental aspect of the definition of inelastic collisions.
  • One participant presents a mathematical derivation involving masses and velocities to illustrate the relationship between momentum and kinetic energy, concluding that for inelastic collisions, initial velocities must be the same for the scenario to hold.
  • Another participant emphasizes the importance of considering energy transformations, noting that inelastic collisions often result in energy being converted to heat due to deformation.
  • Some participants argue that while kinetic energy is not conserved, total energy remains conserved, and they discuss the implications of this distinction.
  • There is a contention regarding the conservation of 4-momentum in the context of collisions involving photons and electrons, with differing views on whether such collisions can be inelastic.
  • Several participants express frustration with the perceived lack of deeper explanations for why kinetic energy behaves as it does in inelastic collisions, suggesting that mere calculations do not suffice for understanding.
Participants generally agree that kinetic energy is not conserved in inelastic collisions and that momentum is conserved. However, there are competing views regarding the implications of this, particularly in relation to energy transformations and the behavior of photons in collisions.
Some discussions involve assumptions about the nature of collisions and the definitions of kinetic energy and momentum, which may not be universally agreed upon. The mathematical derivations presented rely on specific conditions that may not apply to all inelastic collision scenarios.
protonman
Why is KE not conserved in inelastic collisions?
Imagine two objects of masses [itex]m_1[/itex] and [itex]m_2[/itex], traveling with velocities of [itex]v_1[/itex] and [itex]v_2[/itex] which after collding inelastically form a new object of [itex]m_3[/itex], traveling at velocity [itex]m_3[/itex], which due to the conservations of mass must equal [itex]m_1 + m_2[/itex]
We can say this due to the conservation of momentum:
[tex]m_3v_3 = m_1v_1 + m_2v_2[/tex]
therefore:
[tex]v_3 = \frac{m_1v_1 + m_2v_2}{m_3}[/tex]
We can also say that due to the conservation of energy:
[tex]\frac{1}{2}m_3{v_3}^2 = \frac{1}{2}m_1{v_1}^2 + \frac{1}{2}m_2{v_2}^2[/tex]
therefore:
[tex]v_3 = \sqrt{\frac{m_1{v_1}^2 + m_2{v_2}^2}{m_3}}[/tex]
combing the equations we get:
[tex]\frac{m_1v_1 + m_2v_2}{m_3} = \sqrt{\frac{m_1{v_1}^2 + m_2{v_2}^2}{m_3}}[/tex]
square and mutiply [itex]{m_3}^2[/itex] byboth sides,substitue in [itex]m_3 = m_1 + m_2[/itex] and mutiply out:
[tex]{m_1}^2{v_1}^2 + {m_2}^2{v_2}^2 + 2m_1m_2v_1v_2 = {m_1}^2{v_1}^2 + {m_2}^2{v_2}^2 + m_1m_2{v_1}^2 + m_1m_2v_2^2[/tex]
Simply eliminate and you get:
[tex]2v_1v_2 = v_1^2 + v_2^2[/tex]
Which can be re-arranged as:
[tex]v_1^2 - 2v_1v_2 + v_2^2 = 0[/tex]
using the quadratic formula we can solve for [itex]v_1[/itex]
And we find that:
[tex]v_1 = v_2[/tex]
So for an inelastic collision the intial velcoties of the two colliding objects must be the same, hence no collision.
QED
I'm sure there must be a quicker way to prove it, but though I have seen the proof in textbooks, it's completely gone from my mind so I derived it myself.
I'm going to read this as
"Why is total-KE not conserved in inelastic collisions?"
Strictly speaking, an Elastic Collision, by definition, is one in which total-KE is conserved... otherwise the collision is, by definition, Inelastic.
Now, if you were to ask, "Why is the total-KE not conserved when, say, two objects collide and stick?", this can be demonstrated with a short calculation.
To make the calculation trivial, consider the special case of two objects colliding and sticking together with final velocity zero [the total-inelastic or perfectly-inelastic case]. Clearly, the initial total-KE is positive and the final total-KE is zero. (Of course, total-momentum is still conserved.)
These are all obvious trivial calculations. What I am asking is why they turn out this way. Simply going through the derivations is not an explanation.
I don't think the people who write on this site think very much.
Actually robphy made a good suggestion of looking at the problem in the center of mass frame. This at least simplifies the calculations.
The problem here is that energy is not conserved. This is a big problem.
The remaining energy turns into heat. When two pieces of playdough collide, they stick together and all the remaining KE is transferred to heat through the internal friction of the playdough when it is deformed. With a perfectly elastic rubber ball, for example, the energy is stored as potential energy for the time during which the ball is stressed, then it is released in such a manner as to accelerate the ball and none of the kinetic energy is turned into heat. There can, of course, be all cases in between.
Not true.
KINETIC ENERGY is not conserved. An inelastic collision is usually accompanied by deformation of one or both bodies. This requires energy. Thus TOTAL energy is conserved but not necessarily KINETIC ENERGY.
Integral said:
Not true.
But the equation is only considering kinetic energy there is no mention of deformation or internal potential energies.
What equation? Kinetic energy is not conserved, so there is no equation of the form: total kinetic energy before = total kinetic energy after. Momentum, however is conserved, so for two particles,
[tex]m_1v_{1i}+m_2v_{2i} = m_1v_{1f} + m_2v_{2f}[/tex]
It's a silly question then, I only went for the one-dimensional example but the whole point is that by the definition of momentum and by the definition of kinetic energy some energy must be transferred to other forms, kinetic energy can't be conserved in an inelastic collsion which is the question you asked.
If you wanted something deeper, I could've of proved that 4-momentum isn't conserved (which is a useful result as it illustrates why a free electron can't absorb a photon for example), but it amounts to the same thing.
Kinetic energy is conservered in an elastic collision but using the same equation for an inelastic collision it is not conserved.
jcsd said:
It's a silly question then, I only went for the one-dimensional example but the whole point is that by the definition of momentum and by the definition of kinetic energy some energy, kientic energy can't be conserved which is the question you asked.
4-momentum is conserved. Maybe you should read an intro relativity text.
Not in a totally inelastic collison, hence a photon may not collide inelastically with a free electron, though it may collide elastically.
Both photons and electrons have momentum. If they have an equal amount of momentum in opposite directions they will collide and both have a final velocity of zero.
In this case the answer is clear, we find that the ETOT is more than the rest mass of the electron, so the electron must have kinetic energy, but if it did have kientic energy then it must have velocuiity and momentum can't be conserved so the situation is impossible.
You need to start thinking real soon. You are using what is in question to answer the question. I am saying that you can have an inelastic collision between a photon and an electron because you can have to momenta in opposite directions whose sum is zero. Therefore after they collide they will both be at rest.
No. Assume that two identical objects are colliding, with opposite speeds (thus opposite momentums).
Now, total momentum needs to be conserved, so logicly they will have equal speeds (but opposite) at the end of the collision as well. The only limit on the new speeds is that they musn't use more kinetic energy than the original speeds and they must be above or equal to 0. If they have less kinetic energy than before, some of the energy was transformed (into things like the sound of them smashing together, and the heat created by friction), if they have the same amount none was (and, there was no sound to the collision).
The point is, if two things with opposite momentums collide, they don't have to have a final velocity of 0.
m1=1
m2=2
v1=2
v2=-1
1*2+2*-1 = 0 = 1*x + 2*y
x = -2y
Nothing says x or y have to be 0.
m1=1
m2=2
v1=2
v2=-1
x = -2y
You need to read the post before you write.
They do have zero velocity because we are talking about inelastic collisions.
Is there anyone here who can think?
BTW, if you do the calculation out for a photon and electron moving with opposite momentums towards one another it does work out. Using the relativistic momenta.
(Energy of photon)/c - (gamma)(mass of electron)(velocity of electron) = 0
Just solve for the velocity of the electron in this case and see for yourself.
If you're such a thinker, why didn't you think your way out of having to ask a question on this forum? We already told you the energy you're looking for goes to heat , sound, etc. What's the problem?
You may have told me that but you did not support it. You need to provide a reason. I am not here to get answers.
What is happening here is that people who have never thought about this stuff before are being asked questions they have never considered. In this model we are neglecting friction.
God you're obnoxious. I didn't say momenta isn't conserved I said 4-momenta isn't conserved. For 4-momentum to be conserved, energy (which can be seen as the time coponent of 4-momentum) must also be conserved in all reference frames.
jcsd said:
God you're obnoxious. I didn't say momenta isn't conserved I said 4-momenta isn't conserved. For 4-momentum to be conserved, energy (which can be seen as the scalar of the time coponent of 4-momentum) must also be conserved in all reference frames.
Energy is conserved in all reference frames. That is one of the fundamental postulates of SR. Are you sure you know you are on a physics site?
Alkatran: when Protonman said 'inelastic' he meant that the objects stick to each other.
Protonman: Inelastic does not necessarily mean that the objects need to stick. I believe that's referred to as 'perfectly inelastic'. An inelastic collision is anything that does not conserve KE.
In general, the only requirement on the energy that can be written down as an equation is that the total energy is conserved.
i.e : E1(i) + E2(i) + E3(i) +...+ En(i) = E1(f) + E2(f) + ...+ En(f)
where E = tot. energy + KE + PE + other forms (sound, heat, etc - which are also really forms of KEs and PEs of different things)
In the case of an elastic collision, all the KE before the collision is regained after it (through an intermediate conversion into PE and back). So the energy conservation can be wirtten purely in terms of KEs.
ie. KE1(i) + KE2(i) +...+ KEn(i) = KE1(f) + KE2(f) + ...+ KEn(f), since no other forms of energy are involved.
However, for inelastic collisions, we have
KE1(i) + OE1(i) +...+ KEn(i) + OEn(i) = KE1(f) + OE1(f) + ...+ KEn(f) + OEn(f), where OEs are other energies, whose values we may not know, unless a more complete description of the event is given. Since we know not what the OEs are - or even if we do, but find them to be different before and after - we can not write the equation that we write for elastic collisions.
P.S: A free electron can not absorb a photon, because there's no OE possible to put the lost KEs into. However, in an atom, the lost KEs can go into increasing PE, so that's cool, but still a little tricky, because KEs and PEs are quantized.
Physics Lesson One:
What is called the 4-momentum is not really "momentum" in the classical sense. If you differential the space-time 4-vector with respect to proper time you get what is called the momentum 4-vector. This is no more momentum than the space-time 4-vector is actually a spatial displacement. The first component of space-time 4-vector is time multipled by a constant to produce units of distance. Parallel, although not completely similar, thinking applies to the momentum 4-vector.
The reason 4-vectors are defined is that if something can be written in 4-vecotr notation its norm is a Lorentz invariant.
That energy is conserved in all referbce frames, is a result of the fundamental postualtes of SR.
Yes I know what 4-momentum and for a free electron to absorb a phton is a violation of 4-momenta.
Here you imply that energy is not conserved in all reference frames.
Here you say energy is conserved in all reference frames.
jcsd said:
Yes I know what 4-momentum [is] and for a free electron to absorb a ph[o]ton is a violation of 4-momenta.
Can you violate space-time 4-vector?
My apologies, I thought that all sub-atomic collisions weren't (perfectly) inelastic?
jcsd: I don't get what you're arguing. You've been told that the energy goes to heat (from friction) and sound (as well as others, I'm sure...). Do you think the energy just disappears? Why aren't you accepting the answers you wanted?
Lets get back on track. In the center of momentum frame an inelastic collision can be shown to violate conservation of energy. More directly mechanical energy. Trying to explain this by introducing sound and heat is not admissable. We are neglecting friction. The problem still stands.
  • · Replies 25 ·
  • · Replies 21 ·
10K
  • · Replies 18 ·
