Transformer when output circuit is open
When the output circuit of a transformer is open, no current flows through the output coil, resulting in the primary experiencing only the magnetizing inductance and leakage inductance. The absence of current in the secondary prevents back electromotive force (back EMF) from affecting the primary. As impedance is added to the secondary, it reflects back to the primary, appearing in parallel with the primary's magnetizing inductance. Understanding this behavior is crucial for analyzing transformer operation under open-circuit conditions.
  • Understanding of transformer operation and basic electrical principles
  • Familiarity with magnetizing inductance and leakage inductance
  • Knowledge of back electromotive force (back EMF) concepts
  • Basic grasp of impedance and its effects in electrical circuits
  • Study transformer magnetizing inductance and its role in circuit behavior
  • Learn about the effects of secondary impedance on primary circuits
  • Explore back EMF and its implications in transformer design
  • Investigate the relationship between turns ratio and impedance transformation in transformers
Electrical engineers, students studying power systems, and professionals working with transformer design and analysis will benefit from this discussion.
ahmadriaz
can u explain what hapens output circuit is open and no current is flowing through output coil? isn't it that a large current flows through the input?and the wire burns...i know it doesn't hapen...but why?when there is no back emf in primary?
When the secondary is open, all you see is the magnetizing inductance (and the leakage inductance) of the primary. As you add impedance to the secondary so that some secondary current starts to flow, that secondary impedance is reflected back to the primary, where it appears in parallel with the magnetizing inductance of the primary.
Quiz Question -- What is the magnitude of the transformed secondary impedance, as seen in parallel with the primary magnetizing inductance, in terms of the number of turns on the primary and secondary coils?
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 17 ·
