Rate of radiation coming from inside a container
The discussion focuses on calculating the rate of radiation from a source inside an aluminum container with 23 mm thick walls, where the external radiation rate is measured at 542 Hz. The half-life of the radiation source is 2.4 years, and the half-length for aluminum is determined to be 48.36 mm. The correct approach to find the internal radiation rate involves using the exponential law of intensity decrease, resulting in a calculation of 669.3 Hz for the radiation rate inside the container.
  • Understanding of radioactive decay and half-life concepts
  • Familiarity with the exponential law of intensity decrease
  • Knowledge of radiation measurement units (Hz)
  • Basic principles of material absorption in physics
  • Study the exponential decay formula in detail
  • Learn about radiation shielding materials and their properties
  • Explore advanced topics in radiation detection technology
  • Investigate the implications of half-life in practical applications
This discussion is beneficial for physics students, radiation safety professionals, and anyone involved in radiation measurement and shielding analysis.
cyclonefb3
A aluminum container has walls that are 23 mm thick. A radiation detector measures a rate of 542 Hz outside the container. The radiation source inside the container has a half-life of 2.4 years. What is the rate of radiation from the source inside the container?
x1/2=ln2/u
u= 0.014 mm-1
x1/2=48.26 mm
I tried to solve this problem using proportions, and it didn't work. Is there another way?
23 mm is 47% of aluminums half-length (48.36 mm). so the amount of radiation change from inside to outside should be 50% of 47% of aluminums half-lenght.
so 542*23.5% = 127.3
542+127.3 = 669.3 Hz
Proportion doesn't work here. You should use the exponential law of decrease in intension:
[tex]I = I_0 2^{l/L}[/tex]
where [tex]l[/tex] is the length of absorbing material and [tex]L[/tex] is the half-lenght.
