Question regarding force on a square loop due to a magnetic field
The discussion revolves around a problem in electromagnetism, specifically concerning the force exerted on a square loop by a magnetic field described by the equation \(\vec{B}=kz\hat{x}\). The loop is positioned in the yz-plane and carries a current.
  • The original poster expresses difficulty in recalling relevant concepts and seeks guidance on the appropriate formulas to apply. Some participants inquire about the original poster's prior attempts and suggest considering the symmetry of the problem.
The conversation is ongoing, with participants exploring various interpretations of the problem and discussing foundational concepts without reaching a consensus. Guidance has been offered regarding the force on a current element in a magnetic field.
The original poster indicates a lack of recent experience with electromagnetics and expresses a desire to refresh their knowledge without seeking a complete solution.
soumyasch
I am really stuck on this question, can someone help me out?
Code:
Suppose that the magnetic field in some region has the form [B][tex]\vec{B}[/tex][/B]=kz[tex]\hat{x}[/tex] where [I]k[/I] is a constant. What is the force it will exert on a square loop of side [I]a[/I], lying in the [I]yz[/I]-plane and centered at the origin. The loop carries a current [I]I[/I] that flows conterclockwise looking down the [I]x[/I]-axis.
It would be very helpful if the steps that should be followed to solve this problem could be provided. Solution is not solicited. Thanks in advance.
What have you done regarding this? What formula should you use here?
This is not a assignment or homework of mine :) I have been out of touch with electromagnetics for about six years now. But recently I am having a need to refresh what I learned in my first year of graduation. Instead of reading through textbooks all over again, I am trying to go through solutions of problems trying to recall something.
Like I already said, I don't remember much from my graduation course (I am a CSE graduate) (and definitely not names of formulae) and where they are applied. I would be very grateful if someone can guide me on what formulae needs to be applied here (I don't want the solution) so that by doing this a few times I get enough confidence to try a few other problems on my own. Thanks.
The force on an element of current in a magnetic field is given by:
[tex]I d\vec{\ell} \times \vec{B}[/tex]
Take advantage of symmetry.
  • · Replies 25 ·
